Dishwashers Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to know where the filters are that need to be cleaned, glasses are not coming clean during cycle
Anonymous
Level 3:
  • Dishwashers Master 43,501 Answers
  • Posted on Aug 23, 2010
Anonymous
Dishwashers Master
Level 3:
Answers
43501
Questions
0
Helped
10842605
Points
101584
The filtera are under the bottom spray arm..often you need to remove it to get to the filter...but...also...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
3answers
Scotsman prodigy leaking water
How to work on Scotsman Prodigy Ice Machine
No error message and is washing fine but it is rusting all my pots and pans and my cutlery also all my glasses are coming out all cloudy the dishwaser has also always asking for salt we have put in 3 bags...
Hi, I am only a housewife but salt is a corrosive. At home depo, menards, or lowes you can get a dishwasher cleaning kit. Use that to clean your dishwasher. Next because of new state and national laws soaps had to have a change in the chemical make up to have less sulfate or something like that. My glasses were cloudy all the time. I cleaned my dishwasher and now I
only put in dawn dish soap. I don't have to use anything else. My dishes come out clean and spotless. Now you may have to do a little more cleaning on your dishes before you put them in
because your not using regular dishwasher soap but I don't have those spots. Also I put about
a fourth teaspoon of the liquid soap in the 1st cycle soap dish and another fourth teaspoon in the 2nd cycle. You may have to experiment as to the amount you need becasue of how hard your
water is. If you put too much in soap suds will come out during the wash cycles. Hope is works
Marty Mouse the housewife.
Jun 05, 2011 • Dishwashers
,seems as though washing tablet dos not desolve during wash leaving glass with a coating off powder on them,filters have been cleaned
John, clean filters, add salt and rince aid and buy a bottle of dishwasher cleaner and run the cycle on the 70degree setting. Good luck!
1helpful
Black line down page when in COPY mode on MFC-240C
You need to poiwer cycle after cleaning as the scanner only calibrates during power up. If all is clean, even the white bar over the small glass assembly, and you power cycle the machine and it's still there, you will need a new scan assembly.
1helpful
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
3answers
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Kenmore 90 Series Washing Machine. Does it have a filter that needs to be cleaned regularly. I owned a maytag previously. It had a center post that collected lint etc. that needed to be cleaned. I...
It's an auto-clean internal lint filter. Lint is trapped from water circulating through the filter during the wash cycle. During the drain cycle it's backwashed and the lint goes down the drain.
Loud Squeal: Clean and Rinse Cycles
Just on a whim i would say the bearings in the motor are worn.Any leaks?It's also possible that some broken glass went through the screen and into the pump motor if any glass has been broken.
Apr 09, 2009 • Dishwashers
Top arm won't turn
Approximatly how old is your dishwasher?
First step, clean the filter that is underneath the lower sprayer arm. You will probably need to remove several screws to clen it.
While the filter is off, inspect for debris in the pump area (watch out for broken glass that are almost invisible in the water left behind.)
Inspect the impeller for damage and repair/replace.
Reassemble the filter and spray arm - retest.
If the problems remain, the problem is often a failing (weak) pump motor and that is your next step unless you are going to replace with an Enery Star model.
Good Luck!
49helpful
2answers
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
