Question about Refrigerators
I moved a True single door chiller from Derby to Reading (about 3 hrs drive). The machine was laid on its back. The machine was left standing for 6 hrs before switching back on, but, switchrd it off again as its very noisy. Is the compressor faulty or should I have left it standing for longer? Mike
    Scholar:
  • 149 Answers
Let the unit stand for about a day, the compressor oil probably ran to the other parts leave for about a day off it should be fine.
Posted on May 05, 2008
Lying down the fridge on floor could cause any problem ?
Some models of fridge should be kept upright, or, if laid down then should be allowed to stand upright for at least 6 hrs before being switched on.
Oct 29, 2016 | Refrigerators
Fridge Freezer been laid on its back now freezer struggling to freeze
Although there is a lot of confusion out there on this subject, most manufacturer advice is to allow a fridge to stand for at least 24 hrs after being laid down. So unplug the unit and allow it to do that.
One manufacturer advises that a fridge treated in this way may then take up to 72 hrs running before it can recover fully.
Sep 19, 2013 | Refrigerators
Howw do you adjust temp on a Dometic Americana Model 2652
Should be a thermistor probe inside fridge at back, attached to fins. Fins usually frost up from right to left. Note your thermistor location in regards to frosted end, for example: if your thermistor is placed 5 fins from right, move it one closer to frost if too cold, or 1 more away if too warm. Give 24 hrs. to see how it responds. Move further or closer until desired temp is reached. If fridge does not respond at all, you may need a new thermistor. If you have an ohm meter, you can disconnect thermistor at back of fridge at board and test it. Disconnect 2 wire (P2) plug on board (usually at right upper corner) just below 6 wire plug. Now place thermistor probe in a glass of ice-water, at approx. 33-35F for about 3 minutes and check reading at contacts in plug and you should get a reading approx. 7000-10,000 ohms.
Jun 01, 2011 | Dometic RM2652 Refrigerator
We sold a freezer, it was working at the time. The person got it home and plugged it in immediately and left it running for 8 hrs, before contacting us to say that it wasn't cooling. We suggested they...
if they moved it on it's side they damaged the compressor,the machine shouldn't be laid on it's side.if they let it sit for a few days it might have recovered.if it wasn't laid on it's side a wire could have been knocked off somewhere,hard to say without being there to look at it.
Apr 09, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
I was told that I should wait 24 hrs before pluging in a refrigator that had been transported lying down. Is this true?
HI,Yes for most refrigerator you do have wait because the oils come out of the compressor so the oil must settle back down.But some refrigerators you do not have to wait if laid on their side, if it was new in box it will say on box "lay this side down" if not better safe then sorry.
Mar 05, 2011 | Jenn-Air JFC2089H Bottom Freezer French...
Just brought a second hand freezer for garage. It worked at the house but when I brought it back home and plugged it in it didn't get cold I had a green light on and a red hazard light on. Should I have...
The green light means it has power . The red light means the temp is not satisfactory . If the freezer was laid on its side anytime and did not sit for 24 hrs before plugging it in , then it's no good anymore due to compressor pumping solid oil into the lines instead of refrigerant . The oil causes restrictions not allowing the refrigerant to flow .
Sep 26, 2010 | Refrigerators
Sears upright freezer will not come on after a move. Worked fine when we left the old place. Model 253.9244410
Sometimes when you move these, they hydraulic in the line if they were laid on it's side to move. Time is all it needs in this case- about 24 hrs. If it was not laid down, pull the back cover off the freezer and look carefully for loose wires. There will probably be a wire off either there or behind your temperature control.
Apr 23, 2010 | Freezers
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
Need firing order for 4.6 ford
Firing order is 13726548 coil packs are laid out standing in front of the engine
6 3 7 2
1 5 4 8
Cylinder's are numbered
4 8
3 7
2 6
1 5
Apr 08, 2009 | 1997 Ford F150 Regular Cab
WASHING MACHINE
That could very well be the cause of your noise. You will need to remove the back cover of the machine to look inside and see if anything is out of position. Some machines have a concrete block used as a counter weight for the belt drive. You may need to move it back into its holder. The tub could also be out of center. You can recenter it by moving the tub around from the top by the agitator. Make sure all the belts are in the pulleys if it is a belt drive. The back panel should come off by taking out a few screws or bolts.
Mar 11, 2008 | Washing Machines
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
