Question about Frigidaire AEQ7000ES Dryer
My dryer Mode LEQ2152eso is getting very hot in about 15 minutes. Approx 120 degrees on the right top side. Hot enough that you cannot keep your hand on it.I have cleaned the lint filter and remove the vent and cleaned as best I could. I do not know if this is too hot but I am concerned. Thanks for the help.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Does not get hot enough
Some dryers take fifty forvers to dry clothes if the blower wheel is loose. Usually hear a rattle nd the filter will be warped from the over heating. Once she overheats from improper airflow she shuts down the heat. Takes a long time to dry but it eventually does do it. Replace blower wheel this is on norge style dryers with filter inside door. On other models what Floyd said in his links..
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 29, 2015 | Dryers
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Maytag dryer ldg7500 - gas continually turns on & off, no heat
Could be a number of things....
The ignitor is bad and it will not keep pulling enough current to hold the gas vavle on.
The dryer cycling thermostat is bad and is cycling it too often...ie, shutting the gas valve down too soon before it can run long enough and then turning it right back on.
The vent is blocked or plugged and the air gets too hot to fast.
The high limit switch has gone bad doing the same thing as if the cycling stat goes bad.
Fan/blower is bad and bot moving enough air...same symptoms as blocked vent...
Need to start eliminating the possiblities one by one...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Jan 20, 2010 | Dryers
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
SHU43 built in dishwasher
There is no heater element in bosh D/W
Problaby, your hot water is not hot enough and I don't know nobody in your area.Your water heater in your home should be set at 120-140 degrees, read the book to make sure.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dryers Logo
144 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
