How to secure, for example: get a password for my EnGenius wireless router EC-3220
  • 77 Answers
Hi there!
What you can do is configure the wireless router with wireless security. By then, you'll be able to get a wireless key/ passphrase from the router.
Hope this helps!
Posted on May 04, 2008
Setting linksys wireless access point security
Reset the Linksys to "factory settings", including the default logon-ID and password. Login to the router, and enable wireless security, and set a password for your wireless network.
Jul 14, 2014 | EnGenius Computers & Internet
I have several people stealing my signal need to accsess router to secure network and prevent further intrusion.
Please enter the IP address of the Router in the internet explorer and enter the user name and password of the router.(admin, admin). When the windows will open go to wireless security. In that window you can give security option and security password.
Aug 05, 2010 | EnGenius Computers & Internet
I can not log on to the wireless again
You might have changed the password for the wireless, this problem could be solved by pressing the reset button st the rear for 5 sec while the power on and the router will be reset at factory default settings, hope this will solve the problem
Sep 12, 2009 | EnGenius EOC-3220 (EOC3220)
Can not get into the 3220 by ip or serial port
i forget my user name and password of my eoc 3220 router please how can i reset it
Aug 05, 2009 | EnGenius EOC-3220 (EOC3220)
Cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
There no connection betwen my PC and eoc-322o
I have NO EXPERIENCE with this equipment; but have researched this to some degree on the internet. If you are willing to experiment with me we may both learn something. First thing I learned is the difference between ad hoc and infrastructure networks. I have a feeling the default for most wireless routers and wireless adapters is an infrastructure approach. From reading the EEOC-3220 documentation its default is called bridge mode which is an ad hoc network. (this would seem to require reconfiguring your wireless adapter whenever you move from indoors to outdoors -- not desirable.) This can be changed to an infrastructure network by configuring it as an access point which also appears to allow configuration of additional security options including WEP or WPA encryption and MAC checking and could allow hiding the SSID if desired -- all of which apparently could and should match your indoor wireless router. The preferable configuration for the EOC-3220 would be to set an IP address statically (dynamic may be possible) to one valid for the indoor wireless routers subnet and not already used in your indoor wireless router's subnet and disable DHCP on the EOC-3220 and allow your indoor network to control DHCP for the outdoor segment. From what I can tell this configuration should allow the two wireless devices to attach to your PC in a seamless or transparent manner.
Dec 01, 2007 | EnGenius EOC-3220 (EOC3220)
Needs reset
Don't use Engenius...there tech support is terrible and that is very mildly put....I don't use them anymore.....
Nov 30, 2007 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
