Question about Nostalgia Electrics Microwave Ovens
Ccm 600 cotton candy machine..I need a part..It wont heat up anymore.So i think i need the temp controll knob or heating elemnet
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: my r-930ak will not preheat up to running temp
It may be a bad thermistor.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
Posted on Jan 28, 2011
My microwave does not heat. Sounds like it's working just fine....but food is not heated. Is it time to replace it? Panasonic doesn't support it anymore.
By the time you pay for the service call to diagnosis the part needed and labor it can cost anywhere from 250-400 dollars to repair I discourage home owners from attempting to repair a MW parts store lethal voltage even while unplugged there are too many components from the control down to the magnetron that could have failed if not supported anymore I would advise replcment
Apr 06, 2015 | Panasonic Microwave Ovens
Iron model vin068 keeps beeping,wont heat up.
the heater core wont work anymore or the heating system but if u know some knowlegde u can replace it but just buy for the safety..god bless
Apr 04, 2011 | Microwave Ovens
My candy microwave oven with grill and convection.model:CMC 2895 DS. Is rotating but food dont get heated when microwave is set. Then later ater the service man had removed the cover to check where the...
If it is still new and under warranty, the best answer is to exchange it immediately! It sounds like you got a defective unit with either a bad magnatron, a bad power supply, or bad control circuitry. If you had a service man look at it and it is even worse now, you really need to exchange it. If you try to fix it yourself you will void the warranty.
Mar 25, 2011 | Candy Microwave Ovens
My r-930ak will not preheat up to running temp anymore. it heats up but, i think it shuts off at high limit
Jan 28, 2011 | Sharp R-930AK Convection/Microwave Oven
It suddenly won't heat anymore. Turntable still
depends on make and model could be a capacitor issue or a control panel issue
Jan 14, 2010 | Microwave Ovens
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
My Kenmore 64663 still heats but I don'y hear the fan anymore while heating
If it's the internal cooling fan, you really need to get that repaired before you cook anymore with it. Otherwise, your magnetron will be destroyed.
If it's the hood / exhaust fan, then the problem may be the motor or a problem on the control board.If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't feel confident to tackle it yourself, I would contact Sears for service.
Aug 22, 2008 | Kenmore 64663 Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Nostalgia Electrics Microwave Ovens Experts
William Miller
William Miller
Are you a Nostalgia Electrics Microwave Oven Expert? Answer questions, earn points and help others
