Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
I have laars lite 2 heater with the following issue. The gas valve is modulating so that the gas flow to the burner varies somteime it starts and runs normally and at times the gas flow varies and you can hear the gas vakve clicking and the flame stength flucuating and most times it goes out. The parts that have been changes recently are: main gas valve, Low pressure switch ( 2.0 psi), Thermo pile, and igntion control/temperature controller. What else could it be. the problem appears to be intermittent.
    Guru:
  • 630 Answers
Intermittant problems are the hardest to find as they don't show there ugly heads when you are looking for them.
Below is a place I give you for the parts break down of location and pricing, may be useful for you, go to poolcenter.com for this info.
This is an online website that gives you the repair bible for this machine I hope this all helps you as there is a lot of testing to be done http://www.poolheatersguide.com/Lite2-LJ-onlinemanual.pdf Technical support for Waterpik Laars Products is the following phone # (415) 382-8220 extension 260. I hope this info helps, you seem to be into the electrical repair end of things so all this info should lead you to a resolution to your problems, if it shows while you are testing it. Good Luck, any further questions on this call there technical support hotline. Good Luck!!!
Posted on Aug 23, 2010
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Why won't my Laars Lite 400000 heater light?
should be 24 volts ac tyo the brown and yellow wires to the gas valve at start up or when you hear click
Jun 20, 2012 | Teledyne Laars Laars Lite2 Heater 400000...
Laars Lite 2 Coversion to LP Gas
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars-lite LD 97-2000 pool heater wont burn
cycling usually begins as the result of poor water flow caised by debris in the pump, dirty filter or low water level. once you have had some cycling the heater burners and ignitor become sooted and this requires pulling the burner tray, de-sooting the burners and pilot and reassembly. unless you are very competent you may want to call a service tech. Pool heater repair is a high laibility endeavor if done improperly. During the certification class our instructor showed us several houses that were burned down from improper heater repair.
Mar 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Heating & Cooling Logo
51 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
