Question about Panasonic Panafax UF-333 Plain Paper Inkjet Fax
Info code 016 replace battery and code 026 carriage cannot move are displayed on Panafax UF-332..
Download manual - for model 895 the solution is on page 164.
Posted on Jan 18, 2011
Why doe's my fax-mahine need a replacement battery. It say's; Relace Battery Info. code= 026?!
So when the power goes out, you do not loose your stored contacts, Fax transmittal's, and the list goes on.
That is why the battery needs to be replaced,
Questions please ask
please do leave a positive ratings and feedback before you go, thanks
Aug 25, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Replace battry ifo code 026
Pull out the gray tab on top of the operating panel next to the blue lever. The battery is a CR2032.
Jan 01, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf-322 info code 016 carriage cannot move message. Is there a simple fix?
No simple fix.
Open the top cover, turn machine off.
Move the ink carrier to center, knock off the tower of dried ink with a letter opener.
Oil the chrome shaft.
Clean the plastic strip in back of the ink cart with soapy water.
Oct 05, 2009 | Panasonic Office Equipment & Supplies
Manual for panafax uf 585 . it says info code 26 >> replace battery. I dont know where is the socket for battery? Can you please send me a picture for the same or a solution
Hi manish717
You can download a manual free from the following link.
You will have to give your email address.
After downloading, goto page 151 where you will find the answer as how to replace the battery.
http://www.retrevo.com/s/Panasonic-UF-585-Fax-Machines-review-manual/id/313ag417/t/1-2/
Hope this will work for you, Have a Good Day
If this answer helped you, please give a rating
luciana44
Sep 22, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
Sending Documents
First the battery.
Along the top edge of the operation panel you will see a blue tab. just to the left of that tab you will see another beige tab of the same size, this is the battery holder.
Open the toner door and open the feeder ...pull upwards 1 inch until it stops.
Pull the beige tab out...not the blue one.
Take the battery to radio shack or CVS Pharmacy and match it up....CR-2032.
Next step:
press the MONITOR key and listen for a dial tone.
plug a regular phone into the phone jack to check for a dial-tone.
If all else fails.
Press FUNCTION
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
press set
set
wait for the machine to initialize and reboot itself.
Oct 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax uf 780
Make sure you have not installed a Toner Cartridge made for the Panafax 585/595 or one for a Kyocera-Mita KM-F650.or Pitney Bowes
It should be UG-5510
The all look identical.
Jul 24, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Panafax UF-333 No Print Cartridge Error
Pls check in foll order: A.replace with another cartridge. B clean the contact points on the cartridge and the cartridge holder. c.check wheteher the carriage is stuck or too hard ,then oil the rod a bit. D.Please check whether the plastic portion of the carriage wher the cartridge rests may not have broken ? E.The carriage cable may have got cut . f.the carriage sensor might have gone,Please replace the carrriage cable with sensor.. Happy Faxing Omnipresent
Nov 22, 2006 | Panasonic Panafax UF-333 Plain Paper...
Panasonic Panafax UF-333 Plain Paper Inkjet Fax Logo
423 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
