Question about Sony Playstation 3 (PS3) Console
My ps3 work fined at first with the three prongs cable then i used the HDMI and it work fine but when i go to a different tv and use the three prong it wont show nothing, it only works if i uses the HDMI cable
    President:
  • 1,139 Answers
You need to reset the resolution, try these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Aug 23, 2010
  • mitchelweesn Sep 05, 2010
    thanks it worked i tried to use hd cable when problem started?????
  • Kevin Penn Sep 05, 2010
    Yes, when you insert the HDMI cable back into the PS3 is "should" detect it and ask you about changing resolution and all that. Sometimes it won't though but this solution will make it register HDMI.
I turn the playstation on in my television using the three prong wire (yellow, red, white) and it will not work on my television it starts up but it soon sounds like it stopped running. I took the...
Please use HDMI cable to connect the PS3 to your computer when you found that it is working with that it. It only shows that your three prong cable is defective as it fails every time. Try with another three prong cable and see the results. I will still insist you to use HDMI cable which will give you better picture quality and sound.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
MY PS3 WORK FINE WITH A/V CABLES BUT DO NOT WORK WITH HDMI CABLE. I TRIED THREE DIFFERENT HDMI CABLES
most of the time i know that you are using a hdmi cable which caxn be broken and not from a good company or the tv has compatiblity issues ttry using sonys hdmi it will work
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will boot up and the green light is on but i cannot see what is being displayed. i once changed the settings from the three prong to HDMI cable and since then i have not been able to view anything...
1. Turn off the PS3
2. Plug in whatever cable you are going to use
3. Hold the power button down until it beeps once followed by two quick beeps
This resets the display settings to defaults and you will see the picture again.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 is not veiwing on my tv
yeah when you change the setting it will give you a few seconds to ok it but if you dont it reverts back to the hdmi btw the composite ones must be attached so go to cousins house hook up hdmi then switch hook up avi cables then ok go home should work fine
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont display.
you could use the hdmi cable or the composite cable(like the old playstation one with the 3 leads but different colours,not red,white,yellow.)
both would be better for a plasma.
make sure your screen can utilise 1080 for hdmi.
if 720 or 480 use the composite cable.
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
Hdmi cord causing purple and green lines
It may be a ground loop caused by cable televisoin and the Ps3, as PS3 uses a 3 prong plug. Try unplugging the ps3 power cord and see if the lines go away. If they do, it is a ground problem...usually with cable tv. If this is the case, try a good quality power bar with cable suppression jacks on it. It will help eliminate the ground loop in most caese.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
143 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
