Question about Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS)
Where do I go to connect my pc card - Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS)
Below your laptop there is a small cover hold in place by some little screws, remove the screws and the cover, insert the Wireless card, then connect the laptop antenna and put the cover again.
Read the instruction manual of your laptop for more information or post the make/model for more extensive instructions from FixYa experts.
Posted on May 04, 2008
Memory full, install new SD card, how move files to new SD card?
One of these ought to work:
  1. Remove SD card, connect to PC using a card reader (and adapter if needed), copy files to PC. Connect a larger capacity SD card to PC, copy files from PC to new, larger SD card, install new SD card in phone.
  2. Connect phone to PC with USB cable, then do same process as above.
  3. Back up phone to Google, Samsung, or other cloud resource. Replace SD card with larger one. Restore phone from cloud.
Mar 02, 2015 | Samsung Cell Phones
System will not turn on
If you are certian the pc is powered on, check the video card and any new card that has been added to the pc. If you have a video card installed, remove all other cards and retry your boot. If you still have no video, replace the card. If the video connection is on the board and you and have added a new video card, use the "old" connection to open your operating system and configure the video setting to use the new card and change connection.
Good Luck,
C2Solutions
Jan 02, 2012 | HP Pavilion a350n PC Desktop
My device needs to be formatted how do i do this
It is the memory card and use can either use the given connection cable to connect the camera to the PC or remove the memory card to be inserted to the card reader slot in the PC.
On detection of the card, you can right click for formatting on the card and start.
Mar 26, 2011 | Cameras
I need to install the sounds of my pc but i dont know how to do it .thanks..
Hi, Disconnect all power to your PC. Open up the cover your PC (CPU) and find spare connection on *********** ( beside your VGA / video card). If you see a spare, you can install your card there. If you found cover with screw, remove it accordingly. Place your sound card on female adapter securely.Check if there is output audio wires from your cd rom and connect to your sound card. Close the PC cover. Power on your PC. If you have external active speaker, connect it out to sound card audio output. Now you supposed to can play your PC with sound card.
Dec 05, 2010 | ASUS Computers & Internet
Nikon D70s will not format CF card. Have tried different cards with same result. Connected the camera to PC with card installed but PC says no card installed. Is this a firmware problem?
Go into your menu and change the USB connection from PTP to Mass Storage, Then connect to PC and try formatting. be sure to use FAT16 and not NTFS.
Oct 24, 2010 | Nikon Cameras
With an express card on my laptop does this give me wider range of connectability
It will allow you to add connections via the pc slot. However, not all laptop pc cards are compatible with the express card slot. Usually these cards will add connectivity, just like putting a pci card into a desktop.
Feb 15, 2010 | Dell XPS M1530 Laptop
Ok just bought a new graphics card for my other pc and was going to replace the card in this pc but if i connect the graphics card the connections for the monnitor are facing the wrong way(connections...
You apparently are trying a different kind of card in the slot than what the slot takes. The connections would never be inside the computer.
If you want to give more of the specifics I could be more precise. I would need the computer make/model, or the motherboard make/model, and also the graphics card info.
Thanks for using Fixya.
Wayne
Jan 06, 2010 | Acer Computers & Internet
Sound card for ibm 15 g modle
buy a sound card that you like and buy it. all sound card are PCI connections with PCI-E connections models are diffient. But your pc has pci connection. open up your pc and install the card. Listen to your music or play games.
Apr 30, 2009 | Polk Audio IBM PC 300PL Mini Tower...
How to connect AT&T Laptop/Connect PC Card?
looking at the specs for your Thinkpad i believe you can connect your AT&T PC card since it has a Type II interface
Apr 11, 2009 | Lenovo ThinkPad R61i Notebook
I got a SanDisk 3 in 1 SD card. I don't know how to get music off of my computer to the tiny SD card to my phone.
You can connect the SD card to the Card reader or insert the SD card to the SanDisk 3 and then connect the SanDisk 3 to the pc. ( U need the cd utilities and install software to the ROM )
I f your SD card is connected to the PC you can directly copy the music from the PC to the SD card. SD Drive is created by windows found in " My computer" same is through with the SanDisk 3 connected to the PC. you can directly copy the music files onto the sand disk.
Do not rate me if this not solve the sytem. notify if you need more solution. melnavz
Apr 08, 2008 | Computers & Internet
Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS) Logo
61 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
