Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a dixon ride on with 25hp briggs and stratton and it won't turn over as if battery is flat. i replaced the battery with a new one and with a fully charged new battery when i attempted to start is just turned over a couple of times as if i had a flat battery. Could you please help with any info. Regards Terry
  • 395 Answers
Sounds like a poor connection somewhere in the starter circuit. Check all the connections on both ends the heavy cables that run from the battery to the engine and frame. Remove, Clean and Replace if necessary.
Posted on Aug 24, 2010
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
Does a Briggs and Stratton 250035-0111-b1 have a fuel solenoid
The easiest way to check is to look at the bottom of the carb. If there is an electrical wire connected to the bottom of the carb, it has a fuel solenoid. Here is a youtube video Fuel Solenoid on engine
Nov 02, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Jun 17, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
154 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
