Question about Whirlpool Microwave Ovens
Unable to uninstall whirlpool mw model MH6110XBQ-5. Have read other posting on removing mw but none of those solutions work for this model number.Have takin off all front panels and still see no rods or large screws.
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: How do I remove the
Interesting video of how to get into a GE:
Service manual of a late model GE
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 18, 2011
NO HEAT FROM MICROWAVE
use the common sense,clearly, logically, and fix it .God bless you
can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest.jpg mwswitchtest2.jpg If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode. Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Aug 02, 2012 | Kenwood Microwave Ovens
Where is the fuse in under-counter miccrowave?
remove the vent grill at the top, may have to slide to left after screws are removed. then you will see a screw holding the control panel, remove. then slide the panel up slightly and the panel should come off. behind the panel you fine a 20 amp 250 vac glass type fuse. remove and replace. if your MW works cool,,,,, if it does not you may need to call for service.
Jan 23, 2012 | Amana Microwave Ovens
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
How to uninstall a Whirlpool microwave Hood Combination? Model MH6600XV
Unplug the range and move it out of the way.
Open the cabinet above the microwave.
Unplug the power cord.
Remove the 2 bolts going through the cabinet into the top of the microwave.
Have a helper hold the microwave in place before these bolts are removed.
After the bolts are out,assist the helper by lowering the front of the MW and lift the back of it off the mounting bracket attached to the wall.
They are heavy and awkward.
A helper must be used.
Jan 21, 2011 | Microwave Ovens
My Microwave suddenly stopped working. Is there any set up or quickfix I can do. I am not seeing any visible problem as such but heat is not working. MH6110xbq-6 Thanks
Unplug it and take off the cover. If it has a ceramic fuse, it could have gone out. If so, replace it with the SAME model/type of fuse.
Oct 09, 2010 | Whirlpool Microwave Ovens
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
HOW TO UNINSTALL A WHIRLPOOL OVER THE RANGE MICROWAVE. iT IS IN A HOUSE WE JUST MOVED INTO AND IT IS BROKEN. iT IS ALSO HARD WIRED
Since you did not give model number I am providing info for one type of MW that may be similar. If you want specific info for your MW find model number and consult this page: http://shared.whirlpoolcorp.com/product_literature/search.jsp
Otherwise here are the installation instructions I found that you can use in reverse to figure out how to remove your MW.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%20W10238252A.pdf
Aug 11, 2009 | Microwave Ovens
Microwave Ovens Logo
179 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
