Question about C3 RS900LCD 900MHz SixChannel Alarm System with Remote Car Star
I am having problems with my alarm/ remote start system. My remote is not comunicating with my truck
    New Friend:
  • 103 Answers
I am the senior tech support person for Autopage. You will need to do 2 things. First you need to unplug the antenna and let it sit for a few seconds. Then plug it back in. Attempt to hit unlock on the remote. Next step is to completely reprogram the remotes. This can be done by turn the ignition ON 3 times, and then leaving it in the ON position. (ON/OFF, ON/OFF, ON) then press the RED VALET switch 2 times, and holding on the second push (push valet and release, then push valet and hold). Once the siren lets out a long chirp, then release the valet switch, and program the remote by hitting the LOCK button on the remote itself. Program all your remotes you have, until you have programed 4 remote controls into it. It will cancel any prior remote codes. If you still cannot get this correct, you can call my technical support office at 1-800-945-2527 x600. And i will walk you through it.
Posted on Aug 24, 2010
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
When i remote start the truck it will run for about 30 sec. then it will turn off and the alarm will go off. if i started up the truck with the key and then push the remote start when i take out the key it...
Ok. You don't tell us what year, make, or model the truck is, but I'm assuming it is a later model. They all come with integrated alarm and immobilizer systems installed. If you did not get an aftermarket adapter to disable the factory alarm system, then if the vehicle is started without the key it will shut off and alarm after 30 seconds. Once you used the key, you satisfied the manufacturers alarm system and then your remote start worked. You need to get a module specifically designed for your vehicle and alarm system to use with the Viper to make it work. They can be a real pain to get working correctly. Good luck!
Aug 16, 2013 | 5204 Responder LE 2-Way Security and...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
2000 Chevy Impala, alarm remote issues
you should be able to however im not sure if it is associated with the on board system if all else fails reconnect it and maby change the batteries in the remote for a starting point
Sep 09, 2009 | 2000 Chevrolet Silverado
Install aftermarket alarmin 98 jeep
relays are one way but i would suggest a digital control module that will hook up to data line and comunicate the commands from the remote to the car.. Thes emodules control locks, factory alarms. etc... they work great. you can find the right one from bypasskits.com
Aug 21, 2009 | Vehicle Parts & Accessories
Alarm problem on my 2001 elantra
This alarm system can only be 'disarmed' using the keyless remote programmed for this specific vehicle. Press the "Unlock" button on the keyless remote -- this resets/disarms the alarm system. If you do not have keyless remote for this vehicle, get one and have it programmed at a Hyundai Service Center. Problem solved.
May 11, 2009 | 2001 Hyundai Elantra
Can not lock car by key remote . toyota rav 4 53 plate
If your car has an alarm with a separate remote, it is a separate system and it is probably self-arming. When you lock the doors with the key central lock, the alarm gets armed by the RAV4 being OFF and the door locking action. When you unlock the doors with the key, the alarm is still armed because the key is not comunicating with the alarm just the cars factory keyless system.
Mar 19, 2009 | 2008 Toyota RAV4
"Lock system failure"
Hi,this is a comun problem with loocks,put same grease on the moving parts for the lock and you will see it is work,or not?!
Dec 11, 2008 | 2004 Saab 9-3
C3 RS900LCD 900MHz SixChannel Alarm System with Remote Car Star Logo
914 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
