Question about Samsung Digimax S630 Digital Camera
My camera keeps saying "card locked". It will not let me take any pictures, unless I put in my other memory card. But this particular card is not full.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 23, 2010
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
My camera says card locked but I have no memory card in the camera. I can not take any pictures
The camera won't take photos without a card unless that model has a menu setting to allow that option (though nothing is stored). Put a different card in the camera and format it. If it doesn't see the card try formatted it first in the computer and then format it in the camera before you try shooting.
Oct 18, 2014 | Samsung NV10 Digital Camera
My z950 is not reading my memory card. I got it a couple of weeks ago and it was working fine. I took my memory card out to print pictures and when I put it back in, the screen keeps saying internal...
make shore the memory card is out of the camera and reformatte the interal memory and reset the camera ,turn it off and put the memory card back in it should work now.
Aug 29, 2010 | Kodak EasyShare Z950 Digital Camera
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
Camera says Card Locked and I can't Reformat the Memory Card
From the problem described by you, it seem your camera has gone into a internal memory error and hung. Try to take out the battery, the memory card etc , clean and then reinsert and then power on? Try this it might work.... Generally the camera should start working normally once you will take out the battery, since it will reset.
If it still does not work, then think you might need to take it to Canon. They are very helpful and could sort out if you have system software problem. But Before that, I suggest that you must take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and then try to reformat the memory card. If you are lucky, you might not need to go to Canon. Best of Luck.
Apr 30, 2009 | Canon PowerShot A530 Digital Camera
Memory card problem
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Rob
Mar 02, 2009 | Kodak EasyShare One Digital Camera
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Card locked
Card lock means that someone switched the little gray sliding lock on the memory card. It prevents the camera from saving new pictures to AND copying pictures from the card. All you have to do is take the card out and slide the little gray slider back into the unlocked position. Take the card out of the camera. On the side of it is a little 'switch'. Flip the switch in the opposite 'unlock' position
1)check the card to make sure the write protect switch isn't on the wrong setting. It's on the side of the Secure Digital card (not memory stick).
2) I hope you're not buying Memory Stick. That's for Sony. You should be buying support digital.
3) Check the card contacts--if the card isn't making good contact in-camera, you'll get hold of card errors. This happens when someone touches the contacts on the card. Usually cleaning will work unless something sticky get on it. Most memory cards do have exposed contacts, so you enjoy to be careful when handling them ...
4) Format the card in the camera if you grasp an error message. It may just entail to be formatted.Your battery is always drain quickly, that’s symptom of the battery near to run out.,it’s better to change it, your owner's manual say that Lithium AA's will work well and later almost as long.
Hope this may help….
Hope this may help;
DON'T FORGET TO RATE:
Aug 14, 2008 | HP PhotoSmart M627 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Samsung Digimax S630 Digital Camera Logo
117 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
