Question about LG Televison & Video
4 digit sky code for lg m197wdp tv 19 inch - LG Televison & Video
3 Suggested Answers
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
Code for 37LH3000ZA LG TV
Hello
Get into this link. Enter your TV model number and all details. You can get the code for your Tv frm here.
www.sky.com/.../remote.../operate-tv-with-sky-remo... - United Kingdom
Jan 26, 2012 | LG Televison & Video
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
The tv code for model 19LS4D so i can use my sky remote rev 6
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 23, 2008 | LG 19LG30 19 in. LCD HDTV
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Tuning the sky remote.
Phone LG service in Slough, they have the info
Oct 13, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
136 people viewed this question
Computer Repairing
Computer Repairing
