Question about Sport & Outdoor - Others
Hello, what is the torque specs on a 2000 kawasaki ultra 150 cylinder heads?
  • 512 Answers
SOURCE: Head Bolt Torque for a 2000 Grand Cherokee Laredo 4.0L
the torque is a 4 step process
1 torque all bolts to 22 ft/lbs
2 torque all bolts to 45 ft/lbs
3 recheck all bolts to 45 ft/lbs
4 torque bolts 1 thru 10 to 110 ft/lbs
bolt 11 to 100 ft/lbs
bolts 12 thru 14 to 110 ft/lbs
bolt #1 is the fourth bolt from the front on the passenger side....#2 is the fourth bolt on the drivers side then you continue in a clockwise order
Posted on Jan 04, 2009
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
SOURCE: torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Posted on May 09, 2009
outdoorsman5
  • 631 Answers
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. Outdoorsman592003@yahoo.com
Posted on Sep 05, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
1985 Kawasaki ZL 900 A1 Eliminator head bolt torque specs
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kawasaki ZL900 ZL1000 Eliminator 1985 1986 1987 Service Manual Repair... $15
OEM Parts for Kawasaki
1985 Kawasaki ZL900 A1 Eliminator Motorcycle Owners Manual $17
Kawasaki ZL900 Eliminator
Kawasaki Eliminator
Apr 22, 2014 | 1985 kawasaki ZL 900 A1 Eliminator
1987 Kawasaki KDX200 head bolt torque specs
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
kdx head bolt torque specs
KDXRIDER NET View topic Head Torque
Kawasaki KDX200 Service Manual
1988 Kawasaki KDX200 Owner Manual
Jan 06, 2013 | kawasaki Motorcycles
2000 Kawasaki KMX 125 head bolt torque spec
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $22 you can download another one.
2002 KX125 Torque Specs
2001 Kx125 Torque Specs
Kawasaki KMX 125 1986 2002 Service Repair Workshop Manual 1987 1988 1989... $22
http://mybikemanuals.com/kawasaki
Jul 02, 2012 | 2000 kawasaki KMX 125
Kawasaki ultra 150 cylinder torque
kawasaki 260x jt ski cylinder head or specs ?
Jul 01, 2012 | Sport & Outdoor - Others
2003 Kawasaki KX 250 head bolt torque specs
02 Kx 250 Head Bolt torque
Torque of cylinder and cylinder head
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX-125-KX250-Service-Manual-2003-2004-2005-2006-2007-2008.pdf
2003 Kawasaki KX250 Owner Manual
May 28, 2012 | 2003 kawasaki KX 250
1994 Kawasaki KX 250 top end torque specs
Hi, Towens91 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
torque specs 97 Kx250
https://www.scribd.com/doc/121008272/KX125-KX250-94-98-Service-Manual
1994 Kawasaki KX250 Owner Manual
May 25, 2012 | kawasaki Motorcycles
1990 Kawasaki KDX200E2 cylinder and head bolt torque specs
Hi, Mickandkelly for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Kdx 200 Top End Torque Spec
1990 Kawasaki KDX200 Owner Manual
Jan 06, 2011 | kawasaki KDX 200 Motorcycles
2007 Kawasaki KX250 head bolt torque specs
Hi, Stuntman105 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
2005 KX250 Torque Specs
2007 Kawasaki KX250 Owner Manual
Apr 16, 2010 | 2007 kawasaki KX250F
2001 Kawasaki KDX 200 cylinder head torque specs
Hi, Scarri47251 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
2001 Kawasaki KDX200 Owner Manual
Oct 08, 2009 | 2001 kawasaki KDX 200
Hi, M_kingdom for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX125-KX250-Service-Manual-Repair-1999-2000-2001-2002-99924-1244-04.pdf
Jul 16, 2009 | 2000 kawasaki KMX 125
Sport & Outdoor - Others Logo
104 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
