Question about HP OfficeJet 6210 All-In-One InkJet Printer
My priinter has lost connection with my computer and thus will not print. It was not listed under printers on my computer. I do not have the c.d. for it any longer
    Genius:
  • 1,478 Answers
I will advice you check HP web site to download the printer driver, the driver to all HP printers are available at there web site or get a friend that have a copy of the printer driver and install on your computer.
You can download the driver of your printer from the link below,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421991&dlc=en&lc=en&cc=us
You can also replace the cable that connect the printer to your
computer, this can also cause the problem.
Take care.
Posted on Aug 23, 2010
How can I change the default setting to enable Duplex printing
You didn't specify your operating system so I'll go with the most used. My printer is a different model but the process is the same.
To enable/disable duplex (both side) printing (by default):
·from the "Start" button in Windows 7 open "Devices and Printers"
(Select Priinter.jpg)
·RIGHT click on your printer and select "Printing Preferences" If it is a multi-function device (scanner/fax) Select the "printer" (not fax) function.
This will pop up the printer's "Properties" dialog box.
(Printer Properties.jpg)
·On the "General" tab select "Preferences" near the OK button/
(Printing Preferences.jpg)
·Under "Printer Preferences" change the "Print on Both Sides" box from "None" to "Flip on Long/Short Edge". Then click the "Apply" button.
Close all the dialog boxes left open by selecting OK.
Job done.
Feb 16, 2015 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
My printer X5270 has lost connection. In the properties field of the printer, under the General tab the location field is blank and under the Ports tab a check is placed by the USB...Virtual port for USB....
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nb3gkh. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X5270 All-In-One InkJet Printer
Printer only connects wirelessly if i start computer (win 7) first.
go to computer right click properties and select device manager. Or go to control panel and select printers. Delete your printer and then set ip up as a new priinter.
Jun 15, 2011 | Office Equipment & Supplies
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
I bought a new compaq desk top computer and tried to connect with my hp color laser jet 2550n printer. I have windows 7 so I had to install compatible drivers.. It will print but only black & white...
.1.please ensure the color settings of your printer properties in your computer.
2.check the print driver preferences...There may be a setting checked off for Greyscale
3.also ensure the settings in printer
till now problem will be not solved then,
4.uninstall the printer and install again.
note: while you are inslalling the priinter,You do not on the printer;automatically printer software says to ON the printer ,Then you willl on it.
All the best...
Mar 10, 2010 | Computers & Internet
I am trying to print a document however nothing is printing. I have placed new ink cartridges within and the printer takes in the paper and the noise suggests it is printing and recognising the text within...
First thing I always check is the last thing that I did... so ..i fi t worked prior to replacing the ink cartridge/s ..and you replaced them,... did you: peel off the protective tape from the cartridge before installing them? Did you install them correctly.. meaning are they properly seating into the printer and making proper electrical contact with the printer connector? Lastly, are you sure you have the correct ink cartridges installed? After verifying all those things, try printing a test page by going to the control panel..then printers... then select that printer shown with the right mouse button ... and properties in the popup menu for that printer.. it should allow you to 'print a test page'... you may also have a loose cable ( usb or parallel connector ) not seated right between the priinter and the computer... Hopefully, one of the suggestions listed above will get you going... Good Luck..
Jan 30, 2010 | Lexmark X1150 All-In-One InkJet Printer
I was unable to print to a local printer from xp remote desktop, printer connected with a parallel cable. Local printer not displayed from remote desktop. Kindly assist?. The printer is HP Laserjet 2420.
FIRST THING TO CHECK IS IF THE PRINTER IS DISPLAYED IN THE PRINTER WINDOW IF SO RIGHT CLICK ON IT AND GO TO PROPERTIES THEN TO THE PORT SETTINGS AND MAKE SURE IT HAS NOT BEEN SET TO USB OR TCPI PORT YOU CAN SCROLL DOWN AND MAKE SURE IT IS SET TO LOCAL PRIINTER THIS WINDOW AT GENERAL SETTINGS WIL ALLOW YOU TO PRINT TEST PAGE AS WELL
Jun 11, 2009 | Sharp AL-1642CS Copier
I lost the install disk for my Canon ip 2600 printer.
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Need instructions on cleaning rollers
most likely its the fuser. There is burnt toner on the fuser and its damaged
Apr 02, 2009 | HP LaserJet 2420d Printer
My printer
If you're using a MAC System
> Delete the printer in the printer list ( make sure that there's no printer left in the printer list for the CX 8400 )
> Click on the plus sign to add the printer again in the printer list
in the Printer Brouser window you should see the printer listed there via USB connection., Click on it and check under
"Print Using" if the CX8400 driver is listed ( not a guten print driver )
> If CX8400 driver is listed under Print Using., click on add and try to print.
> If "guten print driver" or no driver selected you may need to uninstall the printer driver and download a driver from the epson website.
Steps to uninstall the printer driver:
1.) Make sure that the printer is deleted from the printer list
2.) Click and open MAC or Apple HD / Library / Printer., and look for the Epson folder (drag the whole Epson Folder to your trash bin)
3.) Click and open MAC or Apple HD / Library / Receipts., and look for "Epson Printer driver package or Epson Printer driver.pkg and drag it toyur trash..
4.) disconnect the connection from your Computer to Printer (USB)
5.) Empty your trash bin and restart your computer
Steps to download printer driver:
1.) Download Printer Driver Ver 3.88 epson12439.dmg
try this link > http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
2.) Ones it is downladed to your desktop click and open the file or click on the "Vise X Installer" / Install and then quit
3.) Connect the printer to your computer (USB)
4.) Click on the Apple Icon / System Preferences / Print and Fax.,
Click on the plus sign to add the printer and print
Jun 27, 2008 | Epson CX8400 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
