Question about Whirlpool Duet GHW9150P Front Load Washer
How to change Whirlpool Duet front-load washer (model: GHW9100LW1) rubber seal (the bit gray rubber ring that's between the front door and the drum)?
  • 5,911 Answers
If you are referring to the door bellow, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Aug 23, 2010
Wide gray rubber gasket between door and drum is ripped
the rubber will need to be replaced the cost is around $ 150 you can find washer repair service techs under washer repairs in your local phone book
best of luck
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet front load washer door leaks. How do I get a replacement seal for the door?
YOU NEED A NEW BOOT ON THE INSIDE OF THE DOOR. WHEN YOU OPEN YOUR DOOR THERE SHOULD BE A GRAY RUBBERY RING. AS A MATTER OF FACT, IF YOU MOVE THAT RING AND PUT YOUR FINGERS IN IT YOU WILL PROBABLY FIND A MISSING SOCK OR TWO! THAT RING HAS TORN AND NEEDS TO BE REPLACED.
JB
Aug 23, 2009 | Whirlpool GHW9200L Front Load Washer
Replace Bellow seal duet washer GHW9100LW1
Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black mold growing on and under rubber gasket
it should be a fairly straightforward replacement, these door seals attach to the inner tub and the front case by clamps or straps -view these to check whether its within your capability. these seals should be around the £25 mark. note the chances are these marks may start soon on the new seal !!
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Gray ceramic seal broke.
If you are talking about the counterweights, they can be ordered on line at appliancepartspros.com. Just type in your model number and look under the "Tub and Basket Parts" heading for items 9 and 15. Now depending on which counterweight broke (they are located on the back and front of the tub), the procedures to replace differ slightly. Can you place post back and let me know if it is the front or the back counterweight that is broken? If I am incorrect about the part you are describing, please elaborate a bit more and let me know which part it is.
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rotting Smell from Whirlpool Duet Front Loading Washer
Take the panel off of the front of your washer below the door and in the middle there is a round removable plastic door like piece. Take it out and clean out all of the junk in behind it. You might find loose change, nails and a variety of other thnigs that have become stuck in there besides mold. This will help with the smell and also the water that sometimes remains in your washer after the cycle is over. You need to do this once/twice year.
Feb 12, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet
hiya
firstly you will need to unplug the machine, then remove the lid, open the door and remove the metal retaining band from around the lip of the door seal (may need a small flat screwdriver to lift it up).
once the retainer is off the door seal should pull away from the front lip, this can then be folded inside the machine and out of the way for the next bit.
next you will need to locate the doorseal retainer on the inside of the machine may need a 7mm socket and small ratchet or a small philips screwdriver for this one, this one only needs to be loosened enough so that the doorseal will pull away from the drum.
refitting is pretty much the reverse of removal.
you MUST make sure the seal is on the drum lip corrrectly before refitting the retaining band or it will leak.
you MUST also make sure the drain holes are lined up with the ones on the drum.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
351 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
