Question about Microwave Ovens
MICROWAVE MH1150XMT0. NO POWER TO BOTTOM LAMP SOCKET. TURNTABLE ON SAME CONNECTOR IS OK. HOW DO I REMOVE KEYPAD TO CHECK BEHIND?
GE Advantium - where do I insert replacement halogen bulb inside the microwave?
Posted on May 05, 2008
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Turntable does not turn (work). model:JVM3660SD001
have you check if the unit has the power... & also check if all the settings was made..
Jun 13, 2008 | GE Microwave Ovens
Turntable not working
Possible failure of the drive belt or the turntable motor. Remove the bottom cover to confirm failure of the drive ,belt or if the motor has failed- check power to the motor when the microwave works if the motor tests OK.
Jan 10, 2013 | GE SpaceMaker Microwave Ovens
I have a GE Microwave oven model JVM1790SK01. The surface light switch doesn't work - the lamp stays on all the time; won't dim to night light and won't turn off
There are wires going from the main board to the surface lamp and turntable. They are thin orange, yellow and blue wires. I think the surface lamp is yellow and the turntable wires are orange. You should first try taking the bottom cover off. There are about 8 screws under neath and the bottom cover hinges on the back edge, just let it hang. You can now see the wires. Those wires short to the case where they go through from the main board to the lamps or turntable motor. You now have to move them away form the case. Sometimes they get pinched to the metal cabinet by the lamp socket area. Look for signs of pinched wiring there at the lamp socket or where they go through. Move them away, tape up the bad area.
Mar 21, 2011 | GE JVM1790 1000 Watts Convection /...
No power to unit. Internal fuse ok. Power ok to plug
It sounds like you have a short in the keypad controller system, there is a microprocessor board mounted behind the the keypad that control vital areas of the microwave's operation. I suggest appliance technician to check out the systems hardware and the rest of the oven.
Jan 31, 2011 | Kenmore 80603 Stainless Steel 1100 Watts...
Whirlpool microwave hood combination has code f2 on touch panel. Model number: MH-1150xm
The F2 error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On these models, usually the membrane keypad is not available separately, so you would have to order and replace the control panel frame which comes with a new keypad (sometimes called "panl-cntrl").
The part availability and cost will depend on the full model number from the tag on the unit, and it will be one of these:
MH1150XMB0
MH1150XMB1
MH1150XMB2
MH1150XMB3
MH1150XMB4
MH1150XMQ0
MH1150XMQ1
MH1150XMQ2
MH1150XMQ3
MH1150XMQ4
MH1150XMS0
MH1150XMS1
MH1150XMS2
MH1150XMS3
MH1150XMS4
MH1150XMT0
MH1150XMT1
MH1150XMT2
MH1150XMT3
MH1150XMT4
You can order the part and find helpful exploded view diagrams here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 08, 2010 | Whirlpool MH1150XM Convection/Microwave...
We have a JVM 1443bk02 ge microwave. Today the turntable stopped working. You can depress the key pad on/off button but that makes no difference for the turntable. How do you test to make sure it is the...
The problem with the turntable could be the following:
  1. Gummed up lubrication or bad bearings. Check to see if there is any food on the turntable spindle.
  2. If that is ok, check to see if the belt is loose or broken.
  3. If that is ok, check the motor. A meter will confirm whether there is power going to the motor, when you depress the keypad on button. Use the AC Volts setting, if you have about 21 VAC and the motor does not work, then the motor is bad.
Jan 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My turntable will not rotate. I've checked the piece underneath and it appears to on correctly.
it could be be bad turntable motor.to chk this open up the bottom plate by removing the screws around it.then disconnect the wire connector from the motor.start the unit and chk the voltage with multimeter.if u read voltage then motor needs to be replaced.make sure turntable function is on and not off at the control.if there is no power at the connector then it could be control.chk for any loose wires etc.
Aug 16, 2009 | GE Advantium 120 Convection/Microwave Oven
4175sp microwave has no power to turntable
I assume this is Whirlpool model GH4175sp?
This answer also assumes that yours does not allow for keypad control of the turntable.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
