Question about Hansol H711 SB (Black, Silver) 17 in. Flat Panel LCD Monitor
When i open my computer the monitor is just blinking and monitor is not display anything how can i fix it?
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
The ON/OFF button blinks but no screen image
Since the power led button is on, I think the picture board on your monitor is faulty that is why it is not displaying anything.
Since your computer work perfectly with other monitor, it means the picture board is bad that is why it is not displaying any image.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Acer AL1716 F Monitor
No picture - power button is blinking green
The "blink" is an indication that the monitor is *NOT* getting any signal from your computer's video-card. Either your video-card is the problem, or your computer is "sleeping", and you cannot "wake" it.
Reboot your computer, and watch the monitor, to see if anything at all is displayed.
Reboot with a different monitor connected, to see if anything at all is displayed.
If another monitor works, your monitor is the problem. If neither monitor works, it's the vide-card inside your computer that is the problem.
Aug 13, 2009 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Sampo LCD PD-80A monitor screen blinks on and off every 4...
I just replaced the relay on my second-hand NEC2010X . It would go out after some period of time, but come back if I unplugged it and then plugged it in again. It finally died altogether, but when I replaced the relay, it worked fine. Apparently this relay is the weak link on many LCD's (probably the only moving part in the whole thing). So open it up, unsolder the relay, and put in a new one.
Dec 24, 2007 | Elo 1724L (Dark Gray) 17 in. Flat Panel...
The screen doesn't display
that means the computer is not getting signals from the cpu .. its because of cpu problem .. mainly dust inside hard disk connectors clena and refit memory and hard disk
Dec 02, 2007 | Samsung SyncMaster 793DF 17" CRT Monitor
Hansol H711 SB (Black, Silver) 17 in. Flat Panel LCD Monitor Logo
102 people viewed this question
Top Hansol Computers & Internet Experts
Cleverer2
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
