Question about Vestax PDX-2000MKII PRO Turntable
Turntable speed problem
When i turn on the deck it just starts speeding up an slowing down for no reason
  • Anonymous Jun 09, 2008
    same with mine think it could be the ultra pitch cause wen i mess around with it it somtimes sorts itsself out
I find that if i switch everything off and then unplug the main power the deck then works without lagging.
Posted on Jun 10, 2008
The turntable is not moving at the right speed; just a bit slow. how can the speed be adjusted up a bit? and what to look for?
It all depends on the type of deck. Direct Drive models are more complex as the motor has it's own control circuit where any part can go wrong producing a slower speed.
Belt drive ones are easier to diagnose. The belt being a bit weak can cause it. If you need to replace it make a note of how it fits.
Oil and dirt, grease can cause problems on both types of deck. Grease can build up and cause it to slow up. Sometimes it might need Oil and Grease to be applied!!
There are speed pre-sets, but if the speed slowing is on all speeds then avoid touching them. On belt drive decks a bad motor can cause problems. But it is not common unless the deck is old.
A good test is the movement of the platter by hand. If it feels hard to push it around by hand, or stops very quickly after a good push by hand, then there is something causing drag.
Dec 28, 2015 | Audio Players & Recorders
Why is this turntable running slow?
It depends which type of turntable it is. If a belt one then change the belt, make certain you make a note of how the belt fits before removing it.
Direct drive turntables are more difficult. As it could be any number of faulty parts that cause it.
A build up of grease or dirt in any type of deck can slow the speed down.
A faulty motor on both types of deck will also cause it.
Sep 07, 2015 | Audio Players & Recorders
Zenith IS 4140 turntable is playing records too fast. Can it be slowed down?
All decks have a speed adjuster. Sometimes hidden underneath the turntable, often covered with a sticky label. Some even have two one for 45 and the other for 33. If they are not there they can be found inside it. Sometimes on the power board. Trace the wires from the motor to find it. On some decks it's on the motor itself.
You do have to be careful if the deck is a direct drive model. The speed on these is controlled by a whole variety of devices, any which can cause it to speed up when faulty. But even on a belt driven deck, the power supply to the motor can be to much, caused by a faulty power supply.
May 31, 2014 | Audio Players & Recorders
How to adjust speed from underneath
If it is one of those turntables with the speed pre-sets on the underside, yes it is tricky to do. What I do is get one of those chairs where the seat pops out just leaving the frame. I mount the deck on the chair and thus having access to the pre-set while the deck plays. The only other way is to do it one small turn a time, turning it over then back to play while testing each time. But it's a very slow method!! If you haven't go a chair with a seat that removes, you could try constructing something out of boxes or something, which would be quicker than the other method.
Apr 23, 2014 | Sony PS-LX250H Turntable
I use my Sl1200 with Serato and the other day one of the decks was starting slow. I solved the problem by spinning the record first and then placing the stylus down. But I want it to go back to the way...
p { margin-bottom: 0.21cm; }
HI,
After long years of use the electrolytic capacitors in the circuitry will get slightly change its value. If so it can affect the speed of the turntable. Its better to replace all the electrolytic capacitors in the turntable's electronic circuit board. It will not coast a lot for all the capacitors. Will only come around $3 or $4. .
OK
Oct 28, 2011 | Technics SL-1200MK2 Turntable
1960s stereogram.bsr turntable turning to do fast.
If I can understand you right, the turntable is running fast. I don't think you need a new motor, generally the deck will run slow if the motor is knackered (or not at all). What you need to do is remove the platter, you will find a horseshoe bracket holding it on at the spindle (it may be covered up so you wil have to remove the cover part often a silver disc). The most likely cause will be the rubber idler tyre being worn damaged etc or out of place. There could be grease dirt or something else causing the problem.
Mar 25, 2010 | Audio Players & Recorders
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
My numark ttx deck has started being unable to
Fader has to be ether cleaned or replaced if cleaning did not work.
Nov 17, 2009 | Numark TTX Turntable
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
Vestax PDX-2000MKII PRO Turntable Logo
204 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
