Hi my hp g60 is very slow on start up.... and keeps prompting me about an hard drive failure!!!!!!! is it time to replace the drive????? thanx in advance alex
  • 6,826 Answers
Try to restore to an earlier time or recover the operating system to factory specifications before replacing the drive.
Posted on Aug 23, 2010
Hp g60 235DX WILL NOT BOOT
Having had unusual faults with batteries in these models from similar issues to having no power at all, the least time consuming test would to be remove the battery and power it only from the AC adapter. If it boots okay, the battery is faulty. Next I'd try to access the BIOS, Keep tapping [F10] key straight after pressing the power button and see if RAM and Hard Drive is recognized. If this fails, there may be a motherboard/RAM issue. Then if there are two RAM modules, take them out and insert each one separately, though remove the power and battery before attempting this procedure so as to not risk damaging the RAM modules, I usually keep at least one finger grounded on the metal regions to avoid a potential difference between my body and the RAM. If it boots with one RAM module and not the other, the issue is obvious. If it doesn't boot with either RAM module into the [F10] BIOS, it is likely the motherboard/CPU has failed. IF RAM is okay and then next would be the Hard Drive: With hard drives, sometimes they can mechanically fail, from overheating and bearing failure. This often presents itself as running fine one day and suddenly fails to fire up the next. You can often hear the drive failing to start spinning, though the CPU cooling fan is often too noisy to hear if the drive is spinning or not. Two techniques are useful, take out the hard drive and very gently spin/shake it back and forth manually in the same plane as the disks would spin, normally, sometimes this can free up a stuck drive, if this does, back up all your data while the drive is running and replace it. If this fails, sometimes we can get a failed drive to run by wrapping in a plastic bag and putting in the freezer for an hour. If this works, get what you can off it quickly and replace it, as the control circuits have been cooked.
Note: On all notebooks, air circulation is poor, they should all be placed on flat surfaces, never laps or soft cloth surfaces like on beds, as these block the fine vents and introduce fluff into the unit.
They should have compressed air forced back into the CPU cooling vents regularly to prevent a buildup of a blanket of dust which cooks the CPU and support chips. Keep the cooling system free and clean to get the best out of your notebooks.
Oct 01, 2012 | HP G60-235DX Notebook
I have a HP G60-519wm, pn vm083ua. It gave me an error of no bootable drive and hard disc failure. I replaced hard drive, purchased new recovery discs from HP, and downloaded a boot disc. It still gives me...
try to open the cmos setting by pressing the f10 key then check if the hard drive you installed has been detected, if you can see it, go to boot option then change the 1st boot device to cd-rom drive then the 2nd boot device will be your hard drive then click esc to save the setting put your recovery disk on the cd-rom drive then reboot the unit if ask press any to boot from cd rom just press a key or simple tap any key on the keyboard, then follow instruction.
Aug 03, 2011 | Computers & Internet
I have just copied data to TRANSCEND 25M3 640G USB 3.0, then i run VMWare Image from my external. Then after i want to shut down my laptop, then click safely remove, but it prompt 'USING IT, STOP...
You really can't purchase a USB 3.0 port for you computer, I know for a fact that the G60 doesn't have an expansion port that would allow such a device.
I don't understand the prompt either, to be completely honest.
If you're asking if its prompts you to format the drive, and asks are you sure, that's a good feature.
But, other than that, reply with a little more detail and I'll be glad to go more in depth with you.
Jun 11, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have a HP G60-230US and my CD/DVD drive will not read anything
Hi:
It is possible that the laser optics assembly is defective. But the most common failure is the spindle motor that spins the disc. If you do not hear the disc spin after inserting it, then more than likely the spindel motor is defective. It may easier to just contact Hp for a replacement drive.
Mar 28, 2011 | HP G60-230US Notebook
Boots up. sticks when HP appears on screen. Cant go any where from there except re boot or turn off. HP G60-235DX. Everyone says motherboard dead.??
Sounds more like a faulty HARD DRIVE or a bad ram stick.Computer repair places seem to always say that to get more money.Most of the time its not the motherboard but whats connected to it though.I would unplug the HDD and see if it will go on past that screen.If it does replacing the HDD would probably be the answer.
Oct 26, 2010 | HP G60-235DX Notebook
I have a HP G60-230US PC Notebook and when I try to boot up it says "no bootable device". Any help? joseph.boakai@gmail.com
The error can be two possible things:
1. the hard drive is broken and needs replacement, for this enter the bios pressing f12 when the computer is starting up and make sure the hard drive is detected and shows status ok.
2. The boot sectors of the operating system are lost or corrupted and may need reinstalation of the operating system
Good luck
Aug 16, 2010 | HP G60-230US Notebook
I have a HP G60-440US and it displays replace Hard disk Error 303, so should I just replace the hard-drive?
The error codes which represent the # 300 or above usually indicate that the issue might be with the Hard Drive or the RAM Modules.
You may first try performing the Hardware Diagnostics and check for any issues with the Hard Drive or RAM Modules.
If the issue still persists, it would be better to get the Unit examined at the Service Center.
Hope this Helps.
Jul 06, 2010 | HP Pavilion g60-440US Notebook
Hp g60-120us computer will not boot, passes
hi
You need to set the boot seq to boot first from the dvd or cd drive, and try the dvd or cd in an other computer first!
May 30, 2010 | HP G60-120US Laptop
Hp laptop keeps crashing
May its your hard disk wish have a problem. Try to install your OS on an external hard disk or change the internal hard disk. See what happen. if it show blue screen it may be an hardware error.
Feb 15, 2010 | HP G60-120US Laptop
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
