Question about Creative Labs WebCam Live!
Can not get the web cam to focus its blurry picture
I just bought a logitech C250h web cam and the picture is blurry how do I fix it?
Check
1) If the webcam has a focus ring around the lens to sharpen the image
2) if your computer has the necessary powered USB ports for this model
3) Launch the logitech dashboard (toolbar) start the cam using the Quick Capture menu and adjust while running using the Settings Menu
May 21, 2010 | Logitech Quickcam IM 961361-0403 Webcam
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
My lifecam vx-1000 is blurry picture is not clear
open your cam then try to turn the middle part of your cam clockwise or counter-clockwise.. see if it works.
Dec 03, 2009 | Microsoft LifeCam VX-1000 Webcam
I have a web cam but its showing blurry
Please change the focus of the webcam, (if not available in webcam, you can control from the webcam software--- check the focus utilities)
Jun 27, 2009 | QPS QSIPBL2 Network Camera
Logitech web cam is blurry
somewhere on the camera there will be a focus knob, usually it is the housing just outside the lens that your fingers can grab hold of. she need to turn it until it comes to focus
Apr 23, 2009 | Logitech Webcam
I just installed Logitech 9000 web cam and the video is blurry
The black face plate. Turn to the left and the right untill the picture become clearer. You will need to manually focus the cam
Feb 05, 2009 | Logitech Webcam
Fixed problem A4tech-Pk336mb model of webcam- got blurred picture
make sure you have'nt accidently changed the focus on the cam itself
if your video settings for the cam are set proper i would uninstall and reinstall
Jan 18, 2009 | Computers & Internet
Blurry picture
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
Jan 01, 2009 | Radio Shack VGA PC Camera Webcam
Web cam blurry
There are basically 2 adjustment can be made to focus your webcam, 1st is by the webcam software, try to search from the software any feature that can focus your webcam. The 2nd is the mechanical adjustment on the webcam itself, try to rotate the focus ring (webcam's eye) and see how the picture improvement.
YBC (/\)
Jun 02, 2008 | Micro Innovations IC50C Basic Webcam
Web cam
I suggest that you focus the lens.
On your web cam,where the lens is, can you move/turn a little wheel?
This is the focus wheel.
Or you could try in the webcams settings.
Hope Ive Helped.
Regards,
Sophie x
Feb 14, 2008 | Logitech Webcam
Creative Labs WebCam Live! Logo
19 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
