Question about Toshiba Satellite A135-S4527 Notebook
The following keys have stopped working: W P F H K and L...why and how can I fix it?
Code M4 erro
Service mode, first
1.Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop  0  0  Stop  0  1
for security "Stop 9"
In Security, Select Copy Kit
1. Touch "Set."
2. Press the Clear key to clear the current setting.
If the setting is accidentally cleared, press the Interrupt key to
undo the clearing operation.
3. Enter the desired value from the 10-Key Pad.
4. Touch "Current."
5. Press the Clear key to clear the current value.
If the current value is accidentally cleared, press the Interrupt key
to undo the clearing operation.
Jan 15, 2014 | Konica Minolta DiALTA Di200 Copier
Printer is EXTREMELY SLOW in process , then eventually stops about mid page on 1st page then just STOPS compleley
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.This should fix the problem.
Jul 09, 2011 | HP Officejet 5610 All-In-One InkJet...
I'd tried to fix my brother dcp-120c printer, it was unable to print. i followed the instruction of troubleshooting manual but i cant fixed it. the flash display on my LCD is MACHINE 5A. What will i do?
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head.
Also, try a reset:
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
Code sc541 Ricoh Aficio 350 copier
please follow the instruction and you will reset the copier:
press the follow keys in order:
1. press the yellow key[c] (clear)
2. press 1-0-7 on the number pad
3.press and hold it pressed the red key [c] (stop)
4.When on the screen will appear other menu different from the usual turn off the machine from the main switch (the red switch) and then turn it on after 5 seconds.
Please answer do this is helpful for we to know if is needed some more information.
Jan 22, 2010 | Office Equipment & Supplies
My Copier is showing 0-8 problem and is not working how to fix it?
Try reset the error by following this step :
Perform the following procedure to enter the simulation mode.
["#" key] [Interrupt key] [CLEAR key] [Interrupt key] [1] [4]
[START key]
The machine will be reset and hopefully your trouble too.
When the CLEAR ALL key is pressed, the simulation mode is cancelled.
May 26, 2009 | Sharp Office Equipment & Supplies
Getting error c630 on a kycera mita1525
Hello sir; C630 require reset, procedure as follow;
1, press these key by order and keep holding down.
2 these keys are "stop/reset", "start", "left copy density"
3, press "stop/reset" key again.
4, enter 163, press start.
5, window will show out "CLE"
6, press start to clear.
7, press "stop/reset"key and 001 to exit.
Jan 27, 2009 | Kyocera KM-1510 Copier
Only the quajznm keys are working on my laptop Keyboard.
I would shut down the computer, unplug the keyboard and ignore both overnight and try it again in the morning after inverting the keyboard and slapping (flat handed, not hard) the keys in case she had someting in her fingers when she did it.
Heck, I don't even know which language she managed to call up that only needs those letters - LOL.
If she actually managed to damage it, new standard keyboards are cheap.
Jan 23, 2009 | Computers & Internet
2001 BMW 325i - Key no longer unlocking doors.
if you have a bmw 325i 2001 model try this solution:
if you have one key , go on to the next step. if you have more than one key, like two or more than follow this procedure.
step one: unlock the doors with your key and get in and close the doors but do not lock them
step two: put your key into the ignition and turn it but not to start the engine, do this less than 5 seconds
step three: take the key out of the ignition and put it near the shifter. press and hold the unlock button while pressing the lock button 3 times. you have 30 seconds to do this. the doors should lock and unlock automatically signalling that it the key has been reprogrammed. if you have more than one key follow those steps for each one except for step one. remmember you have only 30 seconds for each key. that should help you.
Jun 20, 2008 | 2001 BMW 325
Help needed on N95 8GB
This problem is from your keypad Ic, Possibly it is working automatically. You need to change Keypad IC and then software re-install.
May 12, 2008 | Nokia N95 Cellular Phone
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
