Question about Motorola Mobility H700 Wireless Headset
Can't pair bluetooth H700 to my phone. - Motorola Mobility H700 Wireless Headset
  • 713 Answers
Here is a detailed solution on how to pair your H700 headset with your phone;
STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
STEP 3. At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
To put your phone in the pairing mode,you have to put on the bluetooth of the phone which is found under the connectivity settings in the menu.
Your h700 headset and your phone are matched up and your problem is solved.
Thanks and take care
Posted on Aug 23, 2010
Yazz226
  • 497 Answers
SOURCE: How to pair up headset with cell phone?
first ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
Posted on Jul 16, 2008
SOURCE: I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Posted on Aug 14, 2008
SOURCE: My Motorola H700 Will Not Pair
I have a sony ericsson W580i that I have been connecting with my motorola S9 for a few months. All of a sudden I started noticing the same problem to where it will not connect. After trying everything else, as a last resort I removed the battery and the SIM card, waited a minute and put it back on. WORKED LIKE A CHARM
Hope it helps
Posted on Sep 18, 2008
SOURCE: H700 bluetooth ear piece - Pairing with new phone
I have an LP vx8700 and want to pair it to my Motorola H700. All is good except the blue light on the ear piece will not stay on for very long. It keeps going out.
Posted on Feb 09, 2009
  • 65 Answers
SOURCE: Light won't stay purple even when boom closed & button held
Depending on the phone... try and remove the current bluetooth device, if there is any. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
The boom should be open when you press the button.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Posted on Jul 31, 2009
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
HOW H700 BLUETOOTH CAN PAIR WITH SONY ERICSSON 750i MOBLIE ?IS THERE ANY SOFT WARE TO BE INSTALL IN MOBILE AND FROM WHERE I CAN SOFT WARE FOR H700 MOTOROLA BLUETOOTH. THANKS
Go into the phone's bluetooth settings and set it to search for devices, then press the answer button on the H700 for about 10 seconds or until the light stays on steady and your phone should pick it up as an available device if it doesn't work the first time, repeat until it picks up the H700 and use the code "0000" when prompted to complete the pairing.
Sep 16, 2009 | Ericsson Cell Phones
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
I need the pairing code
0000 is the default code for the H700.
Mar 16, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
119 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
