Question about Garden
The starter cord fails to retract when assembled, but works fine when not assembled
    President:
  • 1,545 Answers
The starter/recoil pulley units on these machines is on the crankshaft so something evidently is binding the crank or flywheel upon reassembly. This is not an uncommon event. Since it all goes together in a plastic housing and plastic can bend and flex to an extent..I would take a real good look at where the housing mates together upon reassembly. Some of these units have little rubber bumpers that help snug up the case when it is reassembled. Make sure you have these little round bumpers in the correct places or misassembly will occur.
Posted on Aug 23, 2010
  • Roy Cagle
    Roy Cagle Aug 23, 2010
    Also make sure the impeller of the unit is free and clear and able to move freely when it is in the housing. This could easily be where the problem is.
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
How do u fix a loose starter cord people?
Hi Rick:
Most starter cords rely on a recoil spring to make them retract.
Sometimes when the cord is replaced it is longer than the original so just needs to be shortened. Pull the cord all the way out and if you have way more than you use for a pull start, then shortening it is a fast fix.
To do that, pull out the cord a couple of feet. flip a slip knot in it to keep it from retracting, then take the start handle apart and shorten the cord about 6 inches. Should work fine.
If the cord is talready too short to make it shorter, you'll need to put another wind on the spring.
Reply as a COMMENT to this post af you need coaching through that.
Hint. Don't dismantle the spring assembly so it can get out. They are related to rattlesnakes.
Cheers.
Feb 08, 2016 | Garden
Pull cord will not retract when assembled. When I took the head apart it works fine.
The question then becomes 'What's stopping the cord from retracting?'
Friction somewhere along the travel of the cord or the winding mechanism is causing this. Find the rubbing point and correct the alignment. Be sure the spring is correctly wound first before re - assembly. There must be spring tension on the winder mechanism to function correctly.
Other than that, check to see if the cord is tangling on itself and preventing the rewind from working.
Jul 17, 2015 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Starter cord pulled out of the housing, it
if it's new take it back should have a one year warrenty on it if yo can't get it done for free get back to me so I can help you you may have a damaged windind head.
Apr 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Apr 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
