Question about Toshiba Satellite A105 Notebook
The my laptop took some water damage about a year ago, since then the display on the screen has looked like a photo negative. Is there any way to fix this wihout taking it to a repair place?
  • 734 Answers
HI there,
Here's the easiest way for you to troubleshoot this hardware problem.
1. Using an external monitor (whether your own or at a friend's place) which you connect to the laptop, see if the same problem shows on the bigger monitor. On most Toshiba, you'll need to transfer the video signal by holding down the "fn" key and pressing the F5 key oncew you've attached the laptop with the video cable.
a. If the same negative-like appearance appears on the larger montior, it means your problem is with the video chip which is soldered to the motherboard, the plug where the laptop screen attaches to that board, or damaged circuitry in between. This would almost surely cost more to repair than to buy a working used A105.
b. If the external monitor shows up clear and normal, then you have narrowed the problem down to the the laptop screen's connecting cable plug and there's a chance that the cable's end that plugs in has electrically shorted out elements, or the surge from the water shorting some curcuits damaged what's called the "screen inverter" or the LCD screen panel or both.
2. If the result is b., then you should look into what a local laptop repair specialist would charge to double check this and do the replacements. Then, you'd be able to make a decision that fits your personal needs and situation.
Best Regards
Posted on Aug 23, 2010
How do I correct a negative screen?
Do a factory reset. So what is your tablets brand and model?
Jun 07, 2015 | Tablets & eReaders
Acer Aspire E1-571-6650 would not charge. Problem thought to be DC Jack (AC Adapter would not fix and DC Jack seemed loose). Had the same problem a year ago in July and it was fixed. Original charger...
Difficult to comment but if a laptop comes in for me to repair and the hinge is broken and maybe cabinet damage, I would offer to replace the broken parts and replace the DC jack, if it was faulty. It is part of the service but may not be cheap to repair!
Hinges usually become loose and very rarely break.
Did the laptop work on the power supply but not on battery?
Feb 24, 2014 | Acer Aspire Computers & Internet
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
Toshiba laptop screen looks like photo negative
Cause : Display screen problem. Solution : Remove the Screen and check the weir. If there is no problem you need to change your Display... thanks
Aug 29, 2011 | Computers & Internet
Hi I have HP dv6767tx laptop which i purchased in april 2008 But 1 year ago, all of a sudden a bright strip around 1 to 2 inches in thickness appeared on the extreme left of the lcd screen. Affected...
very sorry to tell you that the lcd has gone bad because your laptop shows exact symptoms of this case.
As per what some HP costumers have told me HP takes this as a physical damage and does not give them a warranty even if it is in the warranty cover
Finally you will need to get it replaced
This is the most expensive fix after a motherboard and may cost you $180 or 8000-9000 INR
Jul 26, 2011 | HP Computers & Internet
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
My screen looks like a photo negative..I have a Toshiba Satellite.
Right click on your Desktop, click on Properties, then go to the Settings tab and set the color to 32 bit True Color.
It sounds to me like your display settings are set to monochrome/black and white.
Best Regards,
James
Jul 21, 2009 | Computers & Internet
My printer worked fine when I used it a month or two ago to print color photos. Now it is printing them in negative for no reason. Even when I do a preview before printing the preview shows the photo in...
When you are on the print window at the end of the process, look for a "Preferences" or "Options", then look for tabs or other menus that say "Color" or some sort of "output" mode and see if there is a negative option you can disable.
Apr 16, 2009 | Canon Pixma iP4500 InkJet Printer
HP Pavilion DV7 Display problem
How long have the colors on your display been "reversed/inverted" and looking like a negative....... Did you drop or damage the laptop in any way (sudden shock/bump)? Also, has it been allowed to overheat (if you run the laptop while it is sitting on a soft surface such as a bed, pillow, couch, etc it can allow the motherboard to overheat because it cannot get the airflow through the cooling system through the fan/vents because they are blocked). Have you checked to see if your laptop is included in the "HP Service Enhancement" program???
Mar 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Toshiba Satellite A105 Notebook Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
