The paper with not pick up because one of the small feeders wheels is missing presumably caught inside the machine. It is the third one along from the right. Can you get inside the machine to look for it or see what has gone wrong.
  • marg_brand Aug 23, 2010
    SX600WF Printer
  • 37 Answers
What type of printer is it
Posted on Aug 23, 2010
Printer paper problem add more paper
try to look inside the paper feeder sometimes there was some instances a piece of teared paper or small sediments drop off in there.. if it not, try to check the rubber roller on the paper feeder.. and please check if some springs are dislocated..
Sep 09, 2016 | HP DeskJet 3535 InkJet Printer
Paper out
Could be caused by a few things. Recent paper jam could have caused this issue so should use a can of air for electronics and blow out the wheels and around the paper feeder that grabs and feeds the paper. If printer is small enough can turn it upside down and shake it out could have something dropped into paper feeder. Some HP printers have trap doors in bottom that catch things caught in printer. If it is none of these could be a bad sensor.
Feb 22, 2013 | Tally 6312 Matrix Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Says paper jam, worked fine yesterday but there is no paper even in the machine...
Those errors that deal with paper jams. An error code "6A80" can either represent a sheet feeder error or a debugging unit. This means that there may be scattered bits of paper or other debris trapped inside the unit itself. The potential for this error is high; when the paper is removed from a jammed feeder, bits are prone to fall off and cause this error code. The user must inspect the inside of the printer thoroughly. This error can result from problems with the unit serving or the electronic card; however, the most likely cause is debris caught inside the printer interfering with the printer's operation.
Nov 09, 2010 | Canon PIXMA MX340 Wireless Office...
Feeder is no longer feeding. What should be
Well I don't think you are going to be able to find replacement parts for it. But what you can do is try the following. Turn off the printer, unplug the power cord, remove any paper that you may have in the feeder now pick up the printer and flip it upside down. Be careful with the scanner lid but sometimes what happens is that things will get inside the printer blocking the paper path. That will cause the printer not to pick up the paper most of the time.
Jan 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
Machine will not send messages, Enter FAX No. Push Send and this message appears, Paper Jam
Have you opened up the Document feeder and checked inside?
I sounds like you might have something caught in the paper path.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Paper keeps jaming when trying to print fax it
If the jam is consistent with exiting the drum, there's a chance the drum isn't secure and is the paper is getting caught on the exposed area of the drum. If this isn't the case, there may be paper caught in the feeder wheels.
Oct 18, 2009 | Brother IntelliFAX 4100 Laser Fax
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
14 people viewed this question
k24674
