Question about Craftsman Convertible 25cc. Gas Line Trimmer
I am unable to remove the line spindle on a dual feed craftsman 216.51716
    President:
  • Craftsman Master
  • 1,545 Answers
Try and see if the users manual is any help. They should have instructions. Go To: www.searspartsdirect.com
Download the manual for your specific model and it should help.
Posted on Aug 25, 2010
I have a craftsman model 351.221060 I can not get the spindle to spin. Is there a safety feature that I am missing?
if you cannot get the spindle to spin by hand then the bearings are frozen remove the spindle you can get the whole or remove the bearings go to a auto parts store and match the bearings up with new ones the same size depending how much work u want to do but it will save you money,
Aug 20, 2017 | Craftsman Garden
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
I need to feed the line back into the holes on the craftsman 17' 25cc weed trimmer. I dont know how to remove the line holder to replace
Although it is called dual line, only one line is used - except that you use both ends of the line. Cut off as much line as you think the spool will hold. Put the two ends together to find the center of the line. Some trimmers have holes to thread the lines through and others have a place to hook the bend at the middle of the line. if yours has threading holes, thread one end of the line through each hole and then pull on both ends until the bend of the center of the line won't allow any more slack. If your trimmer has the place to hook the bend, hook there and start winding the lines in the direction shown on the spool. Be sure one line is on one half of the spool and the other line on the other half. Wind both lines at the same time as smoothly as you can. When the spool is full, insert the loose ends through the trimmer head, insert the spool and pull on the strings. Hope this helps Tim
Here is a site that can help if I did not understand your question correctly:
http://www.ehow.com/how_7872475_replace-craftsman-25cc-line-trimmer.html
Apr 10, 2011 | Craftsman 25cc Gas Line Trimmer
Replacing the dual-line on the 15" Electric trimmer - Do you run the line through the slot on the casing before the outlet hole?
The slots on the string spool are there just to hold the line in place so it doesn't unwind while you are putting the string head back together. You have the strings sticking up, you lower the casing with the eyelet holes down, feed the ends of the strings sticking up through the eyes and then yank them free of the slots so they can automatically feed. So yes, line goes from spool hub to spool slots to casing outlet holes and don't forget to pull it free of the slots.
Oct 11, 2010 | Craftsman Garden
How do you put on new trimmer line on a dual feed weedeater
Enter you machine's model # @ www.searspartrsdirect.com and download your user manual. They will explain this better than I can and have diagrams you can look at to assist.
Aug 19, 2010 | Craftsman Convertible 25cc. Gas Line...
How do I refill the spool with new cord. the whole towns out of the refills. I bought new line, but cannot figure out how to wind the cord onto the black thingy. Its a dual line feed.
The grasshog xp takes .080 heavy duty line, do not use any other grade other then .080!
First remove the orange cap by depresssing the two buttons. Next unscrew the screw and remove the tumbler. You'll want about 50' of line for each of the two spindle slots. Start on the spindle closest to you by inserting about an inch of line into the hole in the base and statr winding it snugly in the direction as show on the spool, take your time and do it nice and neat and the line will last you longer then if you rush and do it sloppy. At the end leave about 6/8 inches and temporarily fasten the end on one of the nitched holders. Start the inside spool from the opposite end that you started the other and repeat the same. Once they are both spooled and temporarily fastened at opposite ends from each other reattach the spool onto the edger, fasten the screw in place and un fasten each end at a time inserting the line through the wholes each on oppoing sides. Then reinstall the safety cap and you are done! For taking 15/20 minutes and 1/4 the cost of buying a new spool and saving throwing the old spool away it is well worth it =)
Jul 15, 2009 | Black & Decker 14" Grass Hog Xp...
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
41 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
