Question about HP LaserJet P3005n Printer
There are pieces coming out of the printer that look like the roller cover. The paper is crinkling and the ink is smirred. Any ideas?
  • 1,110 Answers
Your fusing unit has gone bad. The fuser unit is the assembly that heats up and "fuses"" the toner onto the paper. The upper fuser roller or "sheet" sometimes goes bad and get s tear in it. Thus the problem you are describing. So you need a fusing unit.
Posted on Aug 23, 2010
Why would paper be jamming or getting stuck on right side with black ink every time?
The rollers that advance the paper could have been messed up by the key, therefore crinkling paper and not advancing in proper timing with the ink. It also could have busted of the plastic gears in modern day printers.
Apr 24, 2012 | Epson Workforce 610 All-In-One InkJet...
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
I just got new ink today for my Lexmark X1270 today. Now, though, my printer( When you are looking straight at it) will take the paper onto the right sige and cram together. What should I do?
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Sep 10, 2011 | Lexmark X125M All-In-One Printer
My canon Pixma. When it prints, the sheets come out crinkled!
This usually happens when the rollers that feed the paper through the printer are dirty. Because your printer is still rather new, I'd imagine that it is a dust problem rather that ink overflow. what you should do is get a cotton swab and some 99.9% alcohol and clean the rollers. The rollers will look like black cylinders and will be in locations that the paper goes. there are usually 2 just inside of where the paper is, and you find some under the cover where your ink is. Once you have cleaned the rollers, try to print again ans see if it still comes out wrinkled.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Paper crinkling
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | HP LaserJet 3015 All-In-One Printer
Paper jam in mp610
Feb 09, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error e04-14
Looking at the printer from the front with the top open (like one were changing ink cartridges), I forced (gently) a piece of card stock through the rollers and found there was a small piece of paper stuck in the right side feed rollers. This paper was not visible in any way. Just in case someone doesn't know this, Push the "Start" button to get the rollers turning.
When the next piece of regular paper went through it "bunched" or "crinkled" the leading edge in the same place. Two or three sheets later it all appears to be working normally again.
Hope this helps someone else.
Nev
Dec 29, 2009 | Panasonic DP-C264 Copier
My HP 1320 is crinkling every page. I've cleaned everything, changed the toner cartridge, but still have the problem. Ideas?
If the crinkle is a fanning or accordion, it is time for you to replace the Fuser.
This is almost always the reason.
Other then that, small pieces of paper can be stuck in the printing path, often behind the fuser.
Removing the back cover, and then the fuser is the best choice.
Your User Manual provided with the device shall explain how to remove the fuser, though it is relatively simple with limited tools.
Apr 14, 2009 | HP LaserJet 1320 Printer
HP LaserJet P3005n Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
