Question about Lexmark X560n Laser Printer
Getting error code 093-423 and 093-424 and saying replace black cartridge but we just recently replaced it and it shouldn't be out so soon
  • 4 Answers
SOURCE: error code
well I have had the same thing happen.on the left only use 31[photo]; 32; 34....on the right33; 35..left takes black or 31 photo....right color cartridge only
Posted on Dec 20, 2007
  • 61 Answers
SOURCE: LEXMARK 8350 - Right Printer Cartridge error
take cartridge out again and inspect carefully the circuit inside the printer where the cartride goes. Look for dust, dirt, ink etc. Try using a can of air to clean the area too. Not sure if it will be visible but look for a ribbon cable near the circuit area too that may be loose. You might want to take it to a local computer shop ( not a chain store like best buy etc ) often they can do a simple repair pretty cheap and fast. Good luck
Posted on Jul 31, 2008
onynn
  • 5 Answers
SOURCE: wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Posted on Sep 09, 2009
anantakumarj
  • 330 Answers
SOURCE: my dell 3010cn won't print...says is ready to
goes through below link i hope it will help you.....
http://en.community.dell.com/forums/p/18111151/19403181.aspx
Posted on Nov 05, 2009
  • 275 Answers
SOURCE: I have changed black cartridge but it says error
The cartridges have a piece of clear tape on them which needs to be removed before installation, keeps the ink fresh sort of. Take out the cartridge and then look for the piece of clear tape, remove it gently and re install.
Posted on Dec 03, 2009
What is the solution to 59.51 error on HP 500 color LaserJet printer.
59 error refers to a Printer motor Error.
59.51 however should not appear on screen.
59.5 is a "Print Cartriddge motor Startup error". The last character should be a letter for which Toner (ie. C, M, Y or K). However I would suggest that the 1 would be the Black motor (seeing as it is the top one). Considering you have replaced the DC controller recently I would say the most likely cause is you have either misconnected or not connected a cable. recheck all your DC controller connections and pay particular attention to connectors J1013 (Cyan Motor), J1031 (Magenta Motor), J1032 (Yellow Motor) and J1033 (Black Motor).
OR
1. Check the cyan cartridge for broken pieces and make sure the drum spins. if so, replace the cyan cartridge
2. Check that connections on the cyan print-cartridge drive motor and on the driver PCA are seated correctly.
3. Replace the cyan print-cartridge drive motor.
4.If error persists, Replace the driver PCA.
5. Replace the main drive assembly.
Dec 06, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Why is my Sharp AR 5618 showing F2 subcode 64
I am unable to locate a manual for your model but F2-64 on most sharp machines refers to a black toner supply problem. If you have recently replaced the black toner there is a chance the toner within the cartridge could have compacted & blocked up. If you have a replacement toner cartridge try replacing it, first having completely powered off the machine, replace the cartridge then power the machine back on. If you haven't got a replacement, remove the toner cartridge & gently tap & shake the cartridge before replacing. Again completely power off the machine to reset the error code.
Hope this helps.
Dec 11, 2014 | Sharp Office Equipment & Supplies
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
My hp officejet is displaying a message "remove
Your printer is in Error mode.. Specially with black ink empty message. HP Printer is designed in such manner that it will not allow you do to anything if it gives cartridge error message on printer screen.
you will have to replace the cartridge and align the printer to get it working.
Regards,
Ron
Jun 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says black cartridge empty and color cartridges almost empty, even when replaced with new cartridges. Ist there a way to fix this error...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says install black and ink empty and offline even when replaced with new cartridges. Ist there a way to fix this error or do I have to replace the cartridge sensor inside? Thanks.
Oct 23, 2010 | Office Equipment & Supplies
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X560n Laser Printer Logo
1,557 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
