Question about Fisher and Paykel IWL12 Top Load Washer
Smell coming from machine - can it be stagnant or soapy residue? Can one gain access or flush it?
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
http://www.fixya.com/support/r4356970-clean_washer
heatman101
Posted on Aug 23, 2010
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
Hotpoint Aquarius WD440 Washer/Dryer. After a cycle clothes still smell as if there is stagnant water underlying somewhere yet machine has been looked at - nothing wrong. Still working in excellent order...
You can buy a liquid product (I got ours in Lidl) that flushes out and cleans the machine. If one application doesn't work try it again. It's just like cleaning out the dishwasher. Worked for us and it was really smelling!
Aug 24, 2011 | Hotpoint Aquarius WD63 Front Load...
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
For several days now we have been experiencing a stagnant cheesy smell that seems to be coming from somewhere in our Liebherr fridge. I have really cleaned out the interior but the smell is still...
hi hazel,not sure about this particular model but if you have a drain hole inside on the back, syringe out with clorine bleach(the smell will go in about 30 mins).sprinkle bicarb inside to absorb any residual niffs.
hope this works for you
geoff.
Oct 01, 2010 | Liebherr KES4260 Refrigerator
Moldy mildew smell
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
A carton of milk spilled in the refrigerator draining into the evaporator pan which cannot be accessed. any suggestions to eliminate the sour milk smell
take unit outside........ flush drain evap pan out with warm water and clorine bleach..hope you get all dry residue out......or take it apart and wash out evap pan...can you get to it from underneath???? easier.
if you do not remove milk residue you kitchen will smell forever...remember baby smells????
Feb 19, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Terrible smell coming from washer while in rinse mode.
This is classic bad design actually.
Some washers are worse than others for this.
Use an oxygen based bleach in a trigger spray, and remove the detergent drawer. Use the spray everywhere in there - and remove the drawer completely to wash it in a mild bleach solution.
Use a small brush to remove the mould in there - and flush it down the pipe with more spray.
If you an get a foaming cleanser down there - then even better - or an alcohol based sanitiser spray.
Also wipe over the door seal rubber - as this sometimes collects stagnant water in the folds.
Reassemble, and do a hot wash with a few white hand towels to remove all the bleach.
You may need to do this every month.
Doing hot washes helps - maybe with a cap of bleach.
(I think the manufacturers do this on purpose - so you wash more often - breaks machines - you buy a new one etc.)
Aug 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Zanussi Front Loader washing machine - FLE1216W Bad odour coming from inside the drum. Smells like stagnant water or could be sludge. Tried everything, filter is clean, ran a clear boil wash, and bleach...
I had the same prob -
This was resolved by flushing sump tubes after disconnecting them. the small one was silted up and stank like sewage.
Now have a bleebing which could be related to water levels...
doh!
Jan 05, 2008 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
