Question about Samsung Computers & Internet
My samsung monitor is not working. The power button on it is flashing on and off and I don't have a display on my desktop computer.
  • dave_malan Aug 23, 2010
    I actually talked to samsung and it is still under warranty so I am sending it back. It is a syncmaster 920 nw. This problem happened last week, i restarted the computer and it was working again. Now it seems to be more permanent. The screen does flash up for a split second here and there, but thats it.
    I do not have a lot of time or resources available to me, so I'll be honest, I was kind of hoping for a quick fix here.
    Thanks
    President:
  • 670 Answers
I don't know which monitor that you own, since you did not supply that information. So I will assume this is an LCD monitor. Typically problems are with the digital board or the backlight circuit board. If it is the digital board, the only reasonable way to repair it to find a replacement board.
To determine which board is bad, take a flashlight and shine it on the LCD. If you can see any kind of image, it means that the digital board is working and the problem is with the backlight.
I don't know if you are technical, what I mean is are you able to open monitor and check the components with a meter and know how to use a soldering iron. If this is beyond your ability, then I would advise you to take it to a repair shop and they should be able to fix it for you.
If you have the technical ability, then the problems with the backlight are usually the capacitors that fail and blow, fuses, transistors and the backlight itself that go bad.
Open the case, and find the the power supply board, it will be the one with the large capacitors. Look at the board for any burned or heat damaged parts. If none are found check the capacitors first. If any look bloated or have the tops of the capacitor blown open, then they should be replaced with the same capacity and at least the same working voltage as the damage one.
Fuses should be checked for continuity if the caps look good. If the caps and fuses are good, then check the transistors. Often the transistors fail by short out.
Let me know if you need any more detail on how to troubleshoot by leaving a comment. Also, if you supply the model number, it can help me be more specific about your situation. Hope this helps you.
Posted on Aug 23, 2010
  • Stephen Lam Aug 23, 2010
    Certainly, if the monitor is still under warranty, it best to send it back and have them look it over. Best of luck to you!
My husband's monitor is a Samsung LCD 19" and it
Hi!
Does it have warranty? If so, you can contact your monitor provider to check it with their technical support personnel. If the unit is out of warranty, check if it has power or the power indicator is responding. If responding, try pressing the auto configure button.
Check if the monitor cable is OK. If you have spare working monitor, you can isolate the problem.
If the monitor has the problem, there is a deffective capacitor inside it or a portion that needs to be re-solder.
thanks
Jun 23, 2011 | Samsung Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
The power button is flashing on and off. get no image believe it is in saver mode, don`t know how to get it out. samsung monitor.
It is more likely to have problem in the power supply section, look inside for bad caps first then post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 29, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor will not come on power light blinking blue
According to the manual, the frequency may be out of the range of the monitor. Adjust the frequency to the range needed by the monitor. Normally 60Hz will work fine.
Nov 04, 2009 | Samsung 941BW LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
229 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
