Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stops on the spin cycle...flashes..06...F..and will not drain
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 24, 2010
I have a Kenmore elite HE3T front load. It gets down to 6 min then stops and flashes between 06 and F, what can i do?
Kenmore 110 4996 Use And Care Manual Troubleshooting
  1. "F" Variables [other than FH and F02] (=Electrical Problem)
  2. Select STOP twice to cancel the cycle.
  3. Select DRAIN & SPIN if there is excessive water in the washer.
  4. Unplug the machine for thirty seconds to reset the Central Control Unit
  5. Re-select cycle and press START.
Feb 27, 2015 | Kenmore Elite 45986 Front Load Washer
Does not enter drain and spin cycle on delicate setting
Machine stop at 51 sec after started ,start button flashing nothing is happening ?
Dec 29, 2013 | Amana Washing Machines
Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Mar 29, 2010 | Bosch Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Whirlpool Duet GHW9400 PT4 on any of the cycles, runs 1/4 of the way through the was cycle and stops and starts flashing F 06, pushed cancel once then started the cycle again this worked for awhile. Then...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 16, 2009 | Whirlpool GHW9400 Duet Washer
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the Drive Motor
Check the MCU
Check the Wire Harness
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
