Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars lite 2
The pilot lights in pilot postion and while holding done the pilot starter switch but after a minute, release and turn to on, the pilot goes out???
    New Friend:
  • 70 Answers
You will need to take pilot assembly out and replace thermal couple also check flue
Posted on May 06, 2008
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot won't light
Thermocouple, if the pilot comes on while holding down the gas switch/button and goes out when you release to turn on, the thermocouple is bad.
Jul 26, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
The heat wont turn on and pilot does not stay lit
If this is a M/V heater you must have at least 400mv/dc to hold the pilot valve open. Check to make sure that the pilot is lighting, then hold the pilot valve down for about a minute. If the the pilot goes out you need to see what the m/v reading is. Chances are you have a bad pilot or gen. Replace.
Mar 06, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot low when release button, goes out after turn on
Try replacing the pilot generator which is in the pilot assembly. It is the piece with a silver cable coming out of it and that cable splits open into a red and white wire at the gas valve, That piece holds the valve open once it is hot enough and is likely not putting out enough voltage to do its job.
Jun 14, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
Jun 22, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
May 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
277 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
