Question about Adobe Acrobat 7.0 Professional
I need the typewriter tool on my tool bar but do not see it listed under "tools" like the instructions refer to?
2 Suggested Answers
COMPUTERANNA
  • 10 Answers
SOURCE: not display my photoshop tool bar
IT SEEMS TO BE A PROBLEM OF INSTALLING THE SOFTWARE.SO PLEASE UNINSTALL IT AND AGAIN INSTALL IT
Posted on Feb 02, 2009
Cummins Framing Nailer Parts
Doug, Try the link below and contact them to see if there is a cross reference, your cummins may use the same part as one they have listed. Second link is interesting read, sound s like cummins tool is under another name now. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sawdustzone.org/forum/discussions/around-the-coffee-pot/39712-cummins-tools-what-is-going-on
Aug 13, 2016 | Tools & Hardware - Others
ABS light and traction light and no cruise control
how on earth would the blind know what is wrong.?
scan it? yet?
btw, newer cars cut cruise feature for any signs of danger.
new laws...
the traction needs ABS to work ,so forget that and fix ABS.
ABS needs 2 things to work , brakes and ABS.
so if brakes are bad, then ABS will get upset.
after all, if it cant brake right, how can the puter save you?
if brakes are known to be ok (inspections work here)
but in this case it was BREACHED by you, with out reading the book first.
then scan the ABS. (omg? code for dead sensor?) nah, you caused it..
easy
ABS resets every key on. so...
my guess, if ABS was happy before your actions( you never said)
then you got air in to the system. and failed to follow the FSM instructions on bleeding brakes, in ABS car.
front caliper, did you block the hose with cap, so it didn't allow air to the modulator? oops... never just let them drip... or . max pain.
bleed it again, (using any or all 5 ways to do so, bleeding is skill thing) (many modulators can not just be simply bled)
now Ill quote the 2012 fSM for you , under brakes
Data: -----------------------------------------------------------------
ABS Brake Bleeding
STANDARD PROCEDURE - ABS BRAKE BLEEDING
ABS system bleeding requires conventional bleeding methods plus use of a scan tool. The procedure involves performing a base brake bleeding, followed by use of the scan tool to cycle and bleed the HCU pump and solenoids. A second base brake bleeding procedure is then required to remove any air remaining in the system.
Perform base brake bleeding, (Refer to Brakes - Standard Procedure)(Refer To List 1).
Connect scan tool to the Data Link Connector.
Select ANTILOCK BRAKES, followed by MISCELLANEOUS, then ABS BRAKES. Follow the instructions displayed. When scan tool displays TEST COMPLETE, disconnect scan tool and proceed.
Perform base brake bleeding a second time, (Refer to Brakes - Standard Procedure)(Refer To List 1).
Top off master cylinder fluid level and verify proper brake operation before moving vehicle.
Jul 31, 2015 | 2012 Jeep Liberty Sport 4dr SUV 3.7L V6...
How do I disable the find bar
Im not sure which find bar you are referring to ?
Is it in internet explorer ?
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list Managed add ons
Toolbar extensions Search providers and Accelerators you have if don't need any of them you can disable or remove them.
Jul 25, 2013 | Computers & Internet
Why does iesupport@we-care.com.(5) keep popping up
Hey, you have the We-Care Reminder installed. It's a donation tool. You can uninstall from Add/Remove Programs under Control Panel.
Dec 21, 2011 | Compaq Computers & Internet
Missing tool bar when I uploaded to Explorer 7. I cant click on tools to get it back because I dont have a tool bar to acces
Try to uninstall IE7. Once it's removed, restart your computer then it will revert back to the older version IE6. After that you can opt to install IE7 again or much better a newer version like 8 or 9.
To uninstall IE7, kindly follow these steps:
  1. Close all programs.
  2. Click Start and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 7. In the Uninstall an update dialog box, click Yes.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  6. Follow the instructions to uninstall Internet Explorer 7.
  7. When the uninstall program is finished, restart your computer.
  8. After you restart your computer, open Internet Explorer. Click Help>About Internet Explorer and check if it's on version 6. If it is then proceed with upgrading to a higher version again.
    Hope this helps.
Nov 18, 2011 | Microsoft Internet Explorer 7
When I sign on to AOL, the welcome screen will not load, stays white and the bar at the top says not responding and everything freezes
1. perform browser reset. tools - internet options - advanced - reset.
2. goto add or remove programs - remove all the tool bars.
3. clear temp and prefetch. start - run - type TEMP . start - run - %temp% . start run - prefetch. delete all these junk listed under these 3 locations.
Sep 24, 2009 | Microsoft Computers & Internet
Need new password
If your referring to a new password for your user account, the easiest way to reset it from the password reset tool. If you insert your MacBook install disk, restart the macbook and hold down the option key. Click on the MacBook install disk. Once it loads, there will be a utilities button on the top task bar, click that and click on password reset tool. Once in there, just follow the instructions.
Apr 28, 2009 | Computers & Internet
I need to know how to get to the rear suspension (tower)
i don't think you have to do any repairs from the top end. I will list most fromFord shop manual. Please rate as Fixya if this answers your questions. Please report back. Good luck.
Section 04-02: Suspension and Wheel Hubs, Rear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Spring Rear
Removal
  1. Position a hoist under the rear axle housing, and raise the vehicle. Refer to Section 00-02 . Place jackstands under frame side rails.
  1. Remove rear stabilizer bar as outlined.
  1. Disconnect the lower studs of the two shock absorbers from the mounting brackets on the rear axle assembly .
  1. Unsnap the RH parking brake rear cable and conduit (2A635) from RH upper arm retainer before lowering the rear axle assembly .
  1. Lower the hoist and axle housing until the rear springs are released.
  1. Remove rear spring and rear spring center mounting insulators (5741) from vehicle.
Shock Absorber Removal
Raise the vehicle on a hoist. 1. To assist in removing the upper attachment on shock absorbers using a plastic dust tube, place an open end wrench on the hex stamped into the dust tube's metal cap. For shock absorbers with a steel dust tube, simply grasp the tube to prevent stud rotation when loosening the retaining nut.
  1. Remove the shock absorber retaining nut, washer, and insulator assembly from the stud on the upper side of the frame. Discard nut. Compress the shock absorber to clear the hole in the frame, and remove the inner insulator and washer from the upper retaining stud.
  2. Remove the self-locking retaining nut, and disconnect the shock absorber lower stud from the mounting bracket on the rear axle tube.
  3. Perform Shock Absorber Checks. Refer to Section 04-00 to determine shock absorbers performance.
Installation
  1. Properly prime the new shock absorber . Refer to Section 04-00 , Shock Absorber Checks.
  1. Place the inner washer and rear spring insulator (5536) on the upper retaining stud, and position the shock absorber so that the upper retaining stud enters the hole in the frame. While holding the shock absorber in this position, install a new rear spring insulator , washer and nut assembly on the upper side of the upper frame. Be sure to seat the rear spring insulator in the frame attaching hole. Tighten nut to 34-46 Nm (25-34 lb-ft).
  1. Extend the shock absorber , and place the lower stud in the mounting bracket hole on the rear axle assembly housing. Install a new self-locking retaining nut. Tighten nut to 76.5-103.5 Nm (56-76 lb-ft).
  1. Lower vehicle.
Arm Lower
Removal
Refer to the illustration in Description and Operation. NOTE: To improve rear axle assembly noise and vibration concerns, the rear suspension should be fastened to the frame and rear axle assembly at the curb height position.
NOTE: If one rear suspension lower arm requires replacement, also replace the opposite rear suspension lower arm .
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN REAR SUSPENSION LEVELER COMPRESSOR SWITCH OFF (IF SO EQUIPPED).
NOTE: If both rear suspension arm and bushings and both rear suspension lower arms are to be removed at the same time, remove both rear springs as outlined under Rear Spring Removal. For air spring removal, refer to Section 04-05 .
  1. Mark rear suspension shock absorber relative to protective sleeve with the vehicle in a static, level ground condition.
  1. Raise the vehicle on a hoist, and place jackstands under the rear axle assembly . Refer to Section 00-02 .
  1. Lower the hoist until the shock absorbers are fully extended to relieve rear spring pressure.
  1. Support rear axle assembly under differential pinion nose as well as under rear axle assembly .
  1. Remove and discard the lower arm pivot bolt and nut from the axle bracket. Then, disengage the rear suspension lower arm from the bracket.
  1. Remove and discard the pivot bolt and nut from the frame bracket, and remove the rear suspension lower arm .
Upper
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Suspension Bushing Service Set T79P-5638-A1, A2 and A5 Rear Axle Control Arm Bushing Tools T86P-5638-AH
sra~us~en~file=ani_caut.gif~gen~ref.gif WARNING: TURN OFF REAR SUSPENSION LEVELER COMPRESSOR SWITCH (IF SO EQUIPPED).
  1. Raise the vehicle, and support the frame side rails with jackstands. Refer to Section 00-02 .
  2. Support the rear axle assembly .
  3. Lower the rear axle assembly , and support the rear axle assembly under differential pinion nose as well as under rear axle assembly .
  4. Unsnap parking brake rear cable and conduit from upper arm retainer.
  5. Remove and discard the nut and bolt retaining the rear suspension arm and bushing to the rear axle assembly housing. Disconnect the rear suspension arm and bushing from the housing.
  6. Remove and discard the nut and bolt that secures the rear suspension arm and bushing to the frame bracket, and remove the rear suspension arm and bushing . If upper arm rear bushing is to be replaced, use Suspension Bushing Service Set T79P-5638-A and Rear Axle Control Arm Bushing Tools T86P-5638-AH and the following procedure:
  7. Place the upper arm rear bushing remover tool in position, and pull bushing out. Using Suspension Bushing Service Set T79P-5638-A install bushing assembly into bushing ear of rear axle assembly.
Stabilizer Bar
Removal
  1. Raise vehicle on hoist, and place jackstands under the frame side rails. Refer to Section 00-02 .
  1. Lower the hoist and rear axle assembly housing until the shock absorbers are fully extended.
  1. Disconnect rear stabilizer bars from rear stabilizer bar link and bushing (5C488) . Remove bolts and stabilizer bar bracket (5486) retaining rear stabilizer bar to rear axle assembly .
Mar 05, 2009 | 1994 Lincoln Town Car
My toolbar is greyed out
Hi julie,
I'm not sure which tool bar you are referring to , however , go to> view>tool bars and see if that tool bar is selected(a check mark should be by the ones you want displayed.
anaanymous
Oct 14, 2008 | Acer Computers & Internet
Adobe Acrobat 7.0 Professional Logo
106 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
