Posted on May 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vinage Pioneer amp
Need apower switch for Pioneer amp model #SX939 Part#ask067-0
Anonymous
Level 3:
  • Master 1,512 Answers
  • Posted on May 05, 2008
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829390
Points
3938
HI Hajji
Not much available for these older units any more. The part subs to ASK126 but it is no longer available either. Is the switch beyond repair? What is it actually doing? You can get into most devices like this and repair them sometimes. If it does not turn off, check the cap across the switch. They have a habit of going short cct Let me know how you go.
regards
robotek
How can I download the English version for Pioneer Carrozzeria MRZ99 please?
Japanese only on this model.
How do I change the language on my Pioneer carrozzeria?
Question : I have a carrozzeria AVIC-****. Can I switch the language to English ?
Answer : Carrozzeria AVIC-**** is car navigation & AV model designed and sold for Japanese market only. The language cannot be changed to English, French or any other languages, and the instruction manual is in Japanese only.
Amp turns on I think its a relay little black box click have power click of it goes can I jump this out
The click you hear is the relays switching on the power amp outputs after the amp has successfully run its self diagnosis routine.
The Pioneer Sx315 is a very basic receiver. It does not have 12V switching relays for customer use. You need a higher priced model for that.
Sorry, but your question isn't phrased very clearly. Please can you explain what you want to achieve and the makes and models of the other equipment involved.
2helpful
My steamer on my Breville Die Cast Expresso machine no longer works, I have cleaned it, soaked it in vinegar. Any ideas?
Pleas do not soak this in vinager, try this process with vinager and most cost efficient way to fix this issue with HEAD SPRAYER HOLE clogging is to run vinager through the system several times. The compounds in the vinager serve as a cleaning agent to clean the heads naturally and allow the coffee to travel once again in the same holes it did when you first purchased the unit!!! Just fill up the pop with straight vinager and allow it to run through the system just as if it was coffee! This WILL NOT have any harmful affects to you or the coffee system unless you are allergic to vinager.
I have a pioneer XL2-520 amplifier. I bought it used. So I didn't get the user manual and the sticker on the bottom of amp is not there.. So I was wondering how many watts (rms) in mono mode at 2ohms....
i think its a power acoustik amp im not sure that was a pioneer model. if it is apower acoustik the specs are
125 rms x 2 @ 4 ohms
150 rms x 2 @ 2 Ohms
300 rms x 1 @ 4 Ohms
You can only bridge the amp at 4 ohms dnt go lower than that
Hubby has a CD stuck in stereo and cannot seem to get it out. Will not eject. How do we get it out?
sometimes you can either press a reset switch or disconnect power and it might eject the cd.
Is there a way to put a 300 wat pioneer amp and a 10 inch pioneer sub into my 09 honda civic without replaceing the dash panel?
It is possible to do. You will need a kill switch for the power wire running from your battery to the amp. Also, you will need a high level to low level converter for the audio in signal to the amp. This taps into existing speaker wires and converts it into rca signals to connect to your amp. Its alot more work than taking apart the dash in my opinion.
1helpful
2answers
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
 Grubhead
Grubhead
SmartAviator
SmartAviator
