Question about Husqvarna Chain Saw 20" Bar
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
  • 26 Answers
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Posted on Sep 21, 2011
How to take out the piston in my chain saw
The cylinder must be removed from the crankcase (be sure to clean the exterior of the engine and all parts with compressed air first). That involves removing the carburetor, muffler, cylinder head, and possibly the entire outer case parts. If the piston/ring(s) requires replacement due to scuffing, the cylinder will likely need to be replaced also. Many modern engines use a chrome plated lining for the cylinder interior and any piston damage will affect the cylinder plating also. Use great care when installing the new piston in the cylinder as the ring(s) are quite fragile. Also look for direction marks on the piston as some engines use an offset pin. Be sure to lubricate everything as you go with saw oil to prevent start-up damage. Hope this helps!
Jun 26, 2010 | Echo CS400 18" Chain Saw
How do i remove piston pin from 375 poulan pro
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I suggest you look around the above site. Someone here has been where you are. You can join for free and they are a very helpful group of folk.
Apr 21, 2010 | Poulan Pro Chain Saw 46cc 20"
HOW DO I REMOVE THE CHAINDRIVE CLUCH ON A 359 SAW
My 359 has 3 detents rather than 2 but other than that is like the video.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you need them, part numbers for Husqvarna and Oregon rim sprockets can be found below.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Husqvarna Chain Saw 20" Bar
How do I remove the clutch assembly on my 359 chain saw
Hello ****;
HusqvarnaUSA.com
06 1500198
Lou
Mar 15, 2010 | Husqvarna Chain Saw 20" Bar
How to install clutch ring and bearing on 350 model
Watch this then apply what you saw.
HTH
Lou
Feb 04, 2010 | Husqvarna Chain Saw 20" Bar
My Johnsered 625 chainsaw clutch work????
is it a high idle? most chainsaw's chain continues to turn with a high idle.
Jan 12, 2010 | Garden
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna chainsaw model 359 will not restart after refuel and bar+chain oil refill. Prior to the refuel it was starting within a few pulls. I was bucking a felled pine tree(36'' dia) and saw was running...
Make sure you use the highest octane unleaded fuel you can buy. Make sure your mixture is exactly as prescribed, even the slightest deviation can be a problem. My Husgavarna 359 had the problem just like yours when it was new, new. I would have to take the spark plug out and let it dry out or blow it out with air. It would then run like a top.
Apr 14, 2009 | Husqvarna Garden
Husqvarna 357xp rim sprocket problem
there is a special tool to remove the clutch properly with out damage to the clutch or springs.it is so much easier to take it in some where and have the proper tool used.the tool is $45.00 to $65.00 to buy one.most dealer will only charge you a couple of bucks to remove it and install one for you,it only take a second to do.I,myself have made a couple of differant ones because chainsaw differ so much.let me know and maybe i can get you a picture of the one you need
Feb 07, 2009 | Husqvarna Chain Saw 20" Bar
Husky 359 clutch bearing lube tech
Remove the chain brake cover and check the end of the crankshaft to see if there is a small hole for the roller nose lube gun that should have came with the saw. If so, inject a couple of pumps into this hole which will put grease into the bearing.
If no hole exists then you will have to remove the clutch housing from the saw which can only be done easily with an air or electric impact wrench. The nut comes of in the OPPOSITE direction (counterclockwise) that the nut rotates in when in operation - this should be very easy. Then remove the clutch housing which will expose the needle bearing and using your fingers smear the bearing with a small amount of light high pressure grease. Then replace the clutch housing and turn the nut in the opposite direction you used to take it off with your fingers until it is snug - then use the impact wrench in a very short burst to tighten the nut. Finally replace the clutch housing and/or bar and chain.
For a casual user this should only have to be done once a year as good quality chain oil can get into this area and provide some lubrication.
Jan 25, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
245 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
