Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
I attempt to turn the dishwasher on, but it will not fill with water. Instead, all I get is a humming sound.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Aug 23, 2010
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fills with water then hums
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
No washing action form the dishwasher
sounds like you have a broken wash pump or if there is a humming sound instead of water splash/spray noise ,something is jammed in pump impellors
Oct 05, 2009 | Dishwashers
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
