Question about Acer Computers & Internet
My cursor is frozen an i can not use the computer even if i boot my laptop
  • 320 Answers
Hi try to boot your pc in safe mode (press F8 after switching pc) or try connect mouse to your laptop to see is it working. Let me know, ready to help
Posted on Aug 23, 2010
    President:
  • 3,278 Answers
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
5 Suggested Answers
SOURCE: frozen cursor won't let me use computer or shut it
You can take the power adapter off and also the battery off to turn it off if it doesn't let you shutdown with the cursor.
Cheers
Posted on Mar 02, 2009
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
benwabnick
  • 2404 Answers
SOURCE: Cursor is frozen at boot up.
Hold down the FN key and as your doing that, look for the F key on top where there is a picture of a mouse and press that and it should enable the mouse.
Posted on May 14, 2009
drifterK
  • 4924 Answers
SOURCE: Comaq presario cq 71 cursor
yeah ..you have to disable the power saving mode..This is the only thing related with the battery usage that may disable the cursor..o r..just reinstall the touch pad..
to do that download its driver and run it into computer ..
here is the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795238&
just select eh operation system and download the touch pad driver..
or go to control panel ..open the touch pad icon ..and in there select default settings ..or enable the cursor again ..if it is disabled..
if this is not working ..try reinstall it like I said ..It always starts a clean installation from the factory settings ..
Avoid hibernate it ..cause will always preserve the last settings ..just close it proper each time ..this way it will boot and recognize devices each time from the start ..
Posted on Dec 05, 2011
How i fix a "frozen,unmoveable cursor"
You could have malware going on but if it just seems like it's the mouse chances are it is going bad possibly change the USB port that it is in first
Dec 19, 2015 | Computers & Internet
Lenovo 2.0 laptop cursor is frozen
Hi Julia.
Have you tried restarting your computer? The manual for your device shows there's a keyboard command to turn the cursor on or off.
Fn + F6
I've attached the manual for your reference, below:
http://www.lenovo.com/shop/americas/content/user_guides/g470_g570_g575_ug_en.pdf
Hope this helps!
Mar 28, 2015 | Lenovo Computers & Internet
How do I fix a frozen cursor?
Hi Julia.
Fn + F6
Hope this helps!
Acer laptop cursor frozen
Your mouse function is not working, you can try external USB mouse,
probably the mouse pad is off, check in device manager from system properties in control panel, if it shows mouse installed.
Dec 16, 2013 | Acer Computers & Internet
Comaq presario cq 71 cursor is frozen. PC shop man siad it was poor battery. Booted up from mains and cursor worked fine until recently. Mistakenly left battery in and powered down to hibernate. Now cursor...
here is the link
Dec 06, 2010 | Compaq Presario CQ50-215NR Notebook
Cursor is frozen in microsoft windows 2007 , i can't type
First of all provide detail when does the cursor freezes after booting to the desktop or before and if after are you able to use it after booting to the desktop?
Try to boot in safe mode and check if it works fine then problem is either with your hardware or one of the third party applications or start up items assuming Microsoft and Computer first and second party
Oct 26, 2009 | Acer Aspire 5100 Notebook
May 14, 2009 | Acer Computers & Internet
Frozen cursor on new emachine laptop
Before you plan to return make sure you have done some or all of this things first:
1. Did you reboot after you installed the Enterprise 2007 ?
2. Did you make sure that if its a USB mouse that it is securely connected to the USB port ?
3. Were you able to move your mouse without any problem at all before the software installation ?
4. Have you had this problem before the installation of Enterprise 2007 ?
5. Have you done all your software and windows updates ?
6. Will the mouse work when booting into Safe Mode ( pressing F8 during re-boot before Windows Vista loads) If it does then your softwares need to be updated.
7. Did you check you device manager to see that theres no yellow exclamation anywhere in the Mice and othert pointing devices or under the USB controller section?
8. Is there a legacy USB port to be activated on your computer BIOS ?
If the installation caused your mouse to be frozen then try and uninstall the Enterprise 2007 by using your keyboard and tab to the programs uninstall.
If your mouse still doesn't move after doing all of the above things
then try another new USB mouse. Sometimes you may have to wait for several seconds (even up to a minute for new usb mouse detection) before the USB mouse cursor will move. If the second new USB mouse still wont work then return it to where you bought it as it could be faulty usb connector
Dec 28, 2008 | Computers & Internet
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
