Question about Sunbeam 5891 Bread Maker
Need a belt. do not have a parts list. does it take a belt? stopped turning but motor is running.
  • 433 Answers
Hi. They sell the belts at Amazon for about $10.00. First you should make sure the paddle is not stuck. Take the bread pan out and see if you can turn the paddle by hand. Keep pan out of machine and start a kneading cycle. If motor shaft does not spin then it's probably the belt. Motor and belt is located in base of machine. Make sure you unplug the machine before checking out the belt. Hank
Posted on Aug 25, 2010
Bissell pro 2 brushes dont turn, belts are fine , shaft turns fine. how do i check the motor that turns these parts
You should be able to hear the motor running when it is switched on. If it doesn't make a noise then it isn't running and needs checking. If it does run be aware the drive belts can appear ok but sometimes considerably lose elasticity. so they won't drive. A new belt is often half the length and must be stretched to fit.
If the motor doesn't run and it is a corded vacuum it must be checked through with care. An internal break in the power cord is the most common cause of trouble with a faulty switch number two on my list and a faulty thermal breaker also in the top ten.
In the case of a cordless, first check the charger...
Dec 31, 2016 | Bissell Vacuums
The T202 belt is not in the center
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Jan 21, 2013 | Horizon Academy Sports Fitness T202...
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube,...
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Dec 30, 2010 | Nordic Track Exercise & Fitness
Dryer starts, drum turns a few times then stops. On its own, repeats the attempt to start but has the same issue. For a while it would actually start and complete drying cycle after 3-5 attempts. Now it...
if you can still here the motor running it could be the belt slipping,, try running the dryer with a very light load in it ,,if it works ok,,its the belt slipping and it cant turn a full load anymore,,change the drive belt!
if no motor sounds its the programer,,,pricy part!!!
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
The belt is slipping when running on ithas been standing in cold conservatory
Mar 01, 2010 | Horizon Exercise & Fitness
The belt is slipping with each step
Mar 01, 2010 | Proform XP 590S TREADMILL Drive Motor
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Brush motor does not turn on
I have a similar problem. I disassembled the vacuum and with the belt off, the brush motor runs. But as soon as you put any load on it, it stops. I have been searching the Web trying to find somewhere that sells brush motors for these vacuums, but with no joy. I assume I need a new motor (if I can find one)? Many thanks for any help you can offer.
Mar 29, 2008 | Hoover U5453-900 WindTunnel Supreme Bagged...
Sunbeam 5891 Bread Maker Logo
109 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
