Question about Dishwashers
When the detergent dispensor opens it leaves quite a build up of detergent granules still in the dispensor
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 23, 2010
Why does my detergent latch open up while the dishwasher is running?
If neither the detergent flap open or the rinse aid is being dispensed the this is usually down to a faulty or 'open circuit' solenoid that operates the dispensor unit.
Sep 20, 2014 | Maytag Dishwashers
Fischer paykal dishwasher drawer leaving white powder on dishes
If rinse aid levels in dispensor are ok then check if it is being used. the rinse aid setting may be set too low.
Dec 24, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Maytag quiet series 100 leaves residue and granules all over
are you using powder detergent or liquid. you may just need to switch the type of detergent you use. liquid in my opinion is better. also you may want to check the temperature of your hot water. ideal temp for proper washin is 120 degrees F. also if you run the hot water at the sink first before running the dishwasher, that will help you.
Oct 17, 2011 | Maytag Dishwasher
DDO indicates on the display. Found a magnet that came off of the door dispenser, where does it go on the dispenser?
This is a door sensing magnet . When its in its place it tells the machine that the detergent dispensor is closed and will alow the machine to fill detergent dispensor it goes in the upper right corner of the detergent dispensor handle ... where location 49 is on attatchment newer models have done away with the magnet and the reed switch that senses the magnet this can be jumped out permanetly on the backside of the control panel where the detergent dispensor comes in is a white supository called a reed switch cut this and splice the two wires together and you never have to worry about losing the magnet again... or purchase new control without reed switch......you can always call for tech assistance dr.appliance dr_appliance.png
Feb 23, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES0 front load washer. turn it on and the water fills for 1-2 sec then turns off. replaced pressure switch and control panel. still does the same thing. someone mentioned the door...
does it ever agitate ... if it does than the door is locked ...there is a magnet that falls off these machines the detergent dispensor that tell the washer control board that the detergent dispensor is closed so water wont spray out if left open ,,,,magnet rectangle and size of a pencil rectangle shape .... you can try putting a large size magnet on the opening of dispesor shroud ,,,, usually when you replace the control board they have removed the magnetic dispensor reed switch and just jumped across the board eleminating this connection.
Jan 31, 2011 | Frigidaire Washing Machines
Soap dispensor door won,t open
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
heatman101
Jun 12, 2010 | Dishwashers
We have a Frigidaire Gallery 16 cycle Front loading clothes washer purchased in 2002 and it is leaving what looks like grease streaks and stains on some clothes. We have washed only with Cold water. any...
I removed the drawer for detergent and bleach dispensing and it was
quite dirty form build up of dirt and detergent.
than ran hot water cycles and it seemed to fix.
Oct 14, 2009 | Frigidaire Washing Machines
Automatic dishwashing detergent granules do not dissolve
Did you switch brands of detergent?
You mentioned that the diswasher is old can you check the nozels of the wands to see any of them are plugged near the ends this will affect wheather the water is reaching the door.
Hope this helps
Al
Sep 11, 2009 | KitchenAid Dishwashers
GE Profile Built-in Dishwasher PDW9700L
sorry for the delay. on the modificaton to the dispensor, that , im not aware of anyway. more than likely either something is blocking it from getting full spray of water of simply not enough water in the unit to full expell the detergent
Nov 11, 2008 | Dishwashers
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
