Question about Pool & Spa
Ny guage goes from 1 to 8.What is the lowest amount of Cl? What is the highest"
  • 8,404 Answers
If you are asking what the proper CL level is ... depends ... The National Swimming Pool Foundation subscribes to 2 to 4 ppm. Some states have laws and regulations and guide lines for this. I would suggest you will do good to maintain about 5 ppm CL in your pool ...
Posted on Aug 27, 2010
Popping on acceleration
It could be a problem in the valve train. For a car that old, before putting new parts in, you could buy a compression tester for about $30, and do your own compression test. It should tell you if the engine is good enough internally to warrant proceeding. If compression is low on any cylinders, that problem must be addressed first. If a valve is not sealing and causing the popping, that cylinder will show low compression.
For the test, the engine should be at normal operating temperature. Then pull all the plugs out, connect tester to #1 spark plug hole. Have a helper hold the throttle wide open while cranking the engine over about 5 seconds. Watch the gauge-the first revolution or two will cause the gauge to jump high at first, and successive revolutions during the 5 second span will cause the needle on gauge to climb a little each time. Record or note the compression on #1, then do each cylinder. Try to do the same amount of cranking on each cylinder, and keep the throttle wide open. What you want are compression readings on each cylinder that is well above 100 psi, and all should be close. The lowest reading should be within 75-85% of the highest reading cylinder. Example: say your highest reading is 135 psi. 85% of 135 is 115-so your lowest reading should be at least 115 psi. Some general guidelines: any cylinder with compression below 100 psi is definitely a problem-that cylinder will not have hardly any power output, even if it is firing. Worn piston rings or poor valve sealing is causing compression loss. A newer engine should have compression readings above 150 psi. As the engine wears, compression will drop. In general, for high mileage engines, you would want to see compression in the range of 125-150 psi, the higher the better, but remember, it should be balanced-the lowest should be at least 75% of the highest reading cylinder.
Post back if you have questions-good luck.
Jan 26, 2014 | 1983 Oldsmobile Firenza
Temperature gauge
What is the lowest and the Highest on the Guage?
Mar 05, 2013 | 2002 Chevrolet Cavalier Coupe
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
How to tune the peavy guitar
well. this may sound retarded but every guitar is the same google or youtube how to tune a guitar, also get yourself a guitar tuner there cheap and affordable
Jun 15, 2011 | Peavey Electronics Peavey Predator Plus...
Erratic temp guage but not overheating
Probably the sending unit, and cost about $30.
The test of the gauges is to remove wire from sending unit and watch gauge go to lowest, then ground the wire and watch it go to highest.
If it does, then not a problem with gauge. So must be sending unit.
May 13, 2010 | 1996 Saturn SL
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
May 26, 2008 | Westwind Classic Hugger Polished Brass 52"...
Pool & Spa Logo
74 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
