Samsung plasma model# HPT5054, type# CA50C9, rated input# AC110-120V-60Hz-510W. The rear ant2 input for cable cord was stripped/ pulled out. Tv turns on the input source for cable does show on the screen but cannot recieve cable.
zjut
  • 106 Answers
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Posted on Jan 01, 2008
romsky79
  • 822 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
SOURCE: Samsung Plasma TV
I have this problem too. I have had a technician over to service it twice already and I picked up on a few things he did to fix it. Here is what I learned. the raining pixels has to do with the timing in the circuit boards. Basically telling them when to turn on and off. I would only recomend this solution if you are technically inclined. Remove the back from your tv on the left upper quadrant you should see a small gray dial with marks that a Philips screw driver would fit it. There are three or four of these on the boards scatter across the tv. Each on corresponds to the colors firing in sequence. Take your Philips and turn it to either extream. You should see a your screen go crazy with whatever color corresponds to the dial. Then ever so slowly turn the dial undtil you don't see any more flickering. Do that with each dial and you should be able to get rid of most of the flickering. on the right side of the there is a panel underneath the support bar with orange adjuster. I don't know what they do but they also help reduce the flickering. A word of caution. If you can use something non metallic to adjust these dials. There is a small metal lip to keep the dial from turning too far. If your screw driver touches it. It will fry the dial and your screen will blink red/yellow or blue. and you will have to buy a new board. Luckily they are only about 30 bucks, but I learned the hard way.
Posted on Jun 24, 2009
circuitworld
  • 335 Answers
SOURCE: sound but no video HPT5054 Samsung
One of your transformers on the inverter board are failing to sustain regulated power to the florescent lamps resulting in a dark picture. Also check the SMD fuses on the inverter board(s) see if they have blown. You will need a continuity meter to check them. You can get one from radio shack and be sure to get one with audible sound....you don't have to replace boards when you can fix them.
Posted on Jul 10, 2009
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
How to repair tv blackout
Sustain board fault. Contact any service technician to troubleshoot. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Samsung HPT5054 50 in. HD-Ready Plasma...
No picture and buzzing noise on Samsung HPT5054 50 in. pn51d530a3fxza HD-Ready Plasma Television
Are you just setting up a new tv or is this just a recent issue with a tv you have had for some time? I did find and interesting tidbit on the plasma tv's I didn't know, with regards to the buzzing noise, http://www.samsung.com/us/support/faq/FAQ00022542/22710/ with regards to the lack of picture, I would recommend that you look over your cords and check your connects, see if you can select input with your remote, if you can see the menu then the tv is fine and you just need to reselect the input that your video or whichever option you require such as cable or sat. If this fails let me know and I will do more research for you
Sep 28, 2013 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung plasma tv htp5054 has sound but no picture
call your cable company and ask them for new cables from box to tv
Jul 27, 2012 | Samsung HPT5054 50 in. HD-Ready Plasma...
How do I hook up my little DVD player to my tv?? The DVD player only has red, yellow, and white cords,, where to I plug it in at on the back of the tv and which setting.
New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
Aug 21, 2011 | Samsung 50 in. Plasma TV
Have a plasma samsung hpt5054 i have sound no picture is it worth fixing thanks
On a plasma that usually means a problem in the power sections. You should be able to get an estimate from a repair shop or Samsung repair depot. On that size of tv it should be cheaper to repair than replace unless it is several years old. Usually on a smaller tv just out of warrenty the cost to repair is worth more than just going out and buying a new tv.
As long as you know your replacement cost and get an estimate you will come out on top.
Jun 14, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
Mar 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
