Question about Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
The washer leaks during washing not when filling. It leaks saopy water and rinse water. It is not over filled with water or clothes and happens at all levels and cycles. Also it had started to make a noise,
  • 1 more comment
  • Anonymous May 06, 2008
    LEAKS WATER WHEN RINSING
  • Dawayne May 10, 2008
    Water is leaking during draining and spin cycle. The water is leaking from underneath the machine.
  • gceder012 Aug 18, 2008
    My washer is leaking during the rinse/spin cycle - underneath front. If it is the pump, as suggested, is it worth repairing or should I just look intoa new machine? Current machine is 11 yrs. old.
    Not sure of the exact model #.
  • 117 Answers
If is leaking at the front of your washer its gonna be the pump
Posted on May 09, 2008
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Water is leaking onto floor during filling and also during the rinse cycle.
you will have to check the hoses coming from the water inlet solinoids as it sounds as if there is a leak in one of them.
Jul 27, 2011 | Kenmore 23822 Top Load Washer
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
May 29, 2011 | General Electric WBSR3140GWW Top Load...
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
156 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
