Question about Health & Beauty
Please give me the motor position for the coolant level sensor. I am trying to review why is appearing in a permanent way the radiator drawing. Sorry for my english. Nelson Paulsen Santiago.Chile
Papa Chan
  • 56 Answers
SOURCE: how to replace a coolant level sensor, 2000 buick century
The coolant level sensor is located on the radiator. If you are looking at the engine from the front of the car it will be on the left side. There will some kind of clip holding it in the radiator. Removed the clip and pull the sensor out. You will lose coolant so try to swap it out quick or drain some of the coolant out. Once new sensor is installed, install clip to keep the sensor in place and reconnect the wires to the sensor. Crank the engine and make sure the coolant level is full. This should correct your problem.
Posted on Jan 04, 2009
  • 85 Answers
SOURCE: coolant in coolant reservoir did not fill low level in radiator
you must drain air out of system
so when engine is warmed up, just unscrew slightly the thermo time switch which is the highest sensor and unit in cooling system besides the reservoir, until alittle air releases then when antifreeze starts coming out then retighten to specs. BE VERY CAREFUL !!!! LOOSEN VERY SLOWLY AND NOT COMPLETELY REMOVE FOR THIS CAN CAUSE BURNS. MIGHT WANT TO USE A RAG AROUND SENSOR. If this doesnt solve it then make sure you have the correct rad. cap. Also that the filling hose is not clogged as well as the little port on radiator.
Posted on Feb 19, 2009
polarcycle
  • 1392 Answers
SOURCE: coolant level sensor bad warning comes on console
Coolant sensor wiring would be the next place to look. Make sure connector is good, and look for broken wires.
Posted on May 31, 2009
emissionwiz
  • 76846 Answers
SOURCE: replace coolant level sensor
THESE SENSORS ARE A KNOWN PROBLEM REPLACE IT, IT IS HELD IN BY A WIRE RETAINER CLIP, IT IS LOCATED IN THE PLASTIC SIDE TANK OF THE RADIATOR NEAR THE TOP OF THE TANK, ENGINE SIDE. THE PART IS ABOUT $60.00
Posted on Jul 17, 2009
  • 1986 Answers
SOURCE: Low coolant sensor on a 1998 buick
The coolant sensor should be located near where the upper radiator hose is attached to the engine and has a wire connector on it with 2 wires. It's the only sensor near there. Then there's the sensor that'll be attached to your reservoir tank somewhere along the firewall
Posted on Sep 16, 2009
Testimonial: "Thanks so much for your help! We went right to it!! "
How do I change the temperature coolant sensor in a 2007 pontiac torrent
Locate it near the thermostat. Which is on front of the motor following the the top radiator hose back to the motor . It stops on thermostat housing. The temperature sensor is in the top of the motor it's got a single plug wire with 2 wires in it. Unplug wires use a wrench turn it to the left unscrewing the sensor all the way out using Hi-tech review from the auto parts store red in color apply to the threaded end of the new sensor. Plug in the wires give the Rtv.time to dry. Remove the radiator cap check the coolant level then check the side of over - flow tank also level is marked on the side with a line that says high cold put radiator cap on pushing it down an turn to the right. Hope you are helped by this
Dec 11, 2014 | 2007 Pontiac Torrent AWD
2002 ford windstar sel overheating
first check coolant level in radiator coolant level sound low.if coolant overflow jug empty.coolant sysyem low, when add coolant to coolant overflow jug coolant level should stay at full cold mark.if coolant level okay,engine overheat while sitting or moving in slow traffic either coolant fan relay or fuse could be bad.or engine coolant temperature sensor could be bad. coolant sensor turn on cooling fan at certain temperature.hot wire check to make sure cooling fan motor not bad or short in wires.if all is good have pcm check it controls fan relay to through the coolant temperature sensor signal when coolant get hot.
Nov 04, 2012 | 2002 Ford Windstar
My low coolant light stays on on my 02 impala but the coolant is full how do I reset it?
The coolant level sensor is located on the passenger side of the radiator, just below the bottom of the battery. If the light comes on, you'll need to fill the plastic coolant tank. But you also need to remove the radiator cap and fill the radiator itself. Only open the radiator when the engine is cold. If the radiator is full, and you are positive it's full, then the sensor needs to be replaced.
Feb 22, 2012 | 2002 Chevrolet Impala
Light is on does that mean immediate problem?
Do you have a working temp gage? If not it could be an overheating issue and ruin your motor. More than likely it just an o2 sensor, but any code could hurt your gas mileage. Most auto parts stores will hook up a scanner for free and give you an idea what is wrong.
Mar 01, 2011 | Nissan Axxess Cars & Trucks
Radiator fan not coming on. i replace the 2 relays and the one sensor. what else could it be. i can make the fan work. just unplug from the sensor.
Check fluids. If you are excessively low, the sensor in the radiator will not have anything to read. If the coolant level is OK, you may have a defective thermostat. If the thermostat is defective, this will prevent the hot coolant from inside the motor from reaching the sensor in the radiator..
Dec 14, 2009 | 1998 Ford Contour
Changed expansion tank but light still on any ideas 03 ford escape low coolant level light on dash stays lightup
bad low coolant switch or still low on coolant.
Engine Cooling The cooling system components are the:
  • engine coolant temperature sensor (ECT sensor) (12A648)
  • radiator (8005)
  • degas bottle (8A080)
  • radiator draincock (8115)
  • water pump (8501)
  • water temperature indicator sender unit (10884)
  • water thermostat (8575)
  • dual speed fan motor assembly
The water pump circulates the coolant.
The water thermostat:
  • controls the engine coolant temperature.
  • allows quicker engine warm-up.
The degas bottle:
  • provides a location for fill.
  • contains coolant expansion and system pressurization.
  • provides air separation during operation.
  • replenishes the engine coolant to the system.
The fan motor (8C607):
  • operates only when the ignition switch is in the RUN position.
  • will not operate with the switch in the OFF position.
The engine coolant flows:
  • from the lower radiator hose (8286) to the water pump.
  • from the water pump to the engine block and the cylinder heads.
A closed water thermostat returns the engine coolant to the water pump; an open water thermostat allows the engine coolant to flow to the radiator.
Engine coolant provides freeze protection, boil protection, cooling efficiency and corrosion protection to the engine and cooling components. In order to obtain these protections, the engine coolant must be maintained at the correct concentration and fluid level in the degas bottle.
When adding engine coolant, use a 50/50 mixture of clean, drinkable water and engine coolant.
To maintain the integrity of the coolant and the cooling system:
Dec 07, 2009 | 2001 Ford Escape
Low coolant light 3.8 L
If u haven't replaced the coolant level sensor do so, they are prone to this problem. Here is the part number & a picture, about $44.00
STANDARD MOTOR PRODUCTS Part # FLS24
Feb 09, 2009 | 2002 Buick Regal
Low Coolant warning Light
on the passenger side of the radiator there should be a coolant level sensor several inches from the top facing the engine. they are known for plugging up with sludge or just going bad. They connect with a metal retaining clip around the outside edge and are easy to change
Jan 21, 2009 | 2000 Oldsmobile Silhouette
How to replace a coolant level sensor, 2000 buick century
Dec 20, 2008 | 2000 Buick Century
I have a 1998 chevy caviliar and this light keeps coming. it has a arrow with water underneith what is that
1 IT IS OVER HEATING 2. THE RESERVE IS LOW NO COOLANT OR A DEFECTIVE SENSOR I THE RESERVE TANK
Dec 04, 2008 | 1998 Chevrolet Cavalier
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
