Question about Magic Chef CTB2125 Top Freezer Refrigerator
Adjust front wheels - Magic Chef CTB2125 Top Freezer Refrigerator
  • Magic Chef Master
  • 43,501 Answers
Hi.
Ususally on each side behind the front grille there is a bolt that you can turn that will adjust the level of the front wheels...
heatman101
Posted on Aug 23, 2010
Can i adjust 2006 toyota hiace front wheel bearing
Hey Trevor, Whats going on that you think your front wheel bearing needs adjusting?? Is this a front wheel drive?..If your wheel is loose, you NEED to take this to a qualified professional!!
Jul 06, 2017 | Toyota Cars & Trucks
How do I adjust front wheel height?
Are we talking tractors or mowers here? If its a mower we are talking about there should be adjusters on each wheel. Possibly three holes that you bolt the wheels on. Each wheel should be in the same hole as each other wheel.
Jun 04, 2015 | Garden
How can I adjust my Pride mobility front wheel assembly?
There is a large nut under boot above the front wheel. Loosen that nut for limited adjustment but should be able to get it straight.
Aug 25, 2014 | Pride Health & Beauty
How do I level my fridge?
It is rare that the rear wheels adjust. Most of the adjustment is in the front wheels. They sometimes put screw jacks in the front as well.
Jul 24, 2014 | Kenmore Refrigerators
Greenfield ride on mower front axle/wheels
zYou are correct. there is an adjustment for the wheels. The front wheels are connected to the steering by tie rods, as in a car. This kind of adjustment is not found in a user manual, but you can do it. Inspect how the wheels are connected and inspect the tie rods. The tie rods have to be disconnected from the wheel and turned in or out depending on which direction the wheel needs to go ,in or out. One tie rod is right hand thread. The other is left hand thread. So the adjustment is making the tie rods shorter or longer. If you do a search on the web ' riding mower tie rod adjustment', you'll find plenty of info.
Good luck
May 04, 2014 | Garden
Can i adjust bent or toed out front wheel on 82 bronco?
The toe is adjusted by the tie rod ends connected to the gear box.
Some adjustment is possible where the tie rod ends connect.
Jul 13, 2012 | Ford Cars & Trucks
Have a porter cable 3x21 belt sander and the sand paper keep rolling off the wheels
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
Aug 26, 2011 | Porter Cable Garden
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
Magic Chef CTB2125 Top Freezer Refrigerator Logo
181 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
