Question about Roper RES7646KQ Electric Dryer
Tub not turning. Belt is okay - Roper RES7646KQ Electric Dryer
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 23, 2010
How can I trouble shoot the attached problem..?
It could be something as easy as a sock caught under the agitator. Or if it is an older model the drum break may have stuck on or partially on. I would need to know what model it is?
Sep 04, 2016 | Washing Machines
Agitates but doesnt spin, tub hard to turn
check motor coupler and if belt driven the belt
Mar 28, 2015 | Washing Machines
Squeals during the washers spinning cycle
What model is it? The answer is probably both. Every machine I've worked on has a motor with a belt that drives a pulley that turns the tub held in place by bearings. Your squeal could certainly be caused by a bad belt. If the belt looks bad change it. If it looks okay, try a squirt of belt dressing, if the squeal disappears change the belt. If it is a front loader open the loading door, put one hand just inside the tub at the top (like a waiter carring a tray shoulder high with one hand) and LIGHTLY push upwards then drop your hand a little then push upwards etc., etc. If the whole tub moves solidly you are okay, but if you feel a wiggle or a slight space in the jump (man this is harder to explain than i thought it would be) then your bearings may need attention. I doubt it is your bearings causing the squeal though. Does it squeal through entire spin cycle, or just at the beginning?
Dec 30, 2012 | Washing Machines
Maytag neptunefront load won,t spin mod mle2000ayw
Hi Vinod, the lock light is not on. The motor and belt seem okay; it agitates. I think lock light is supposed to come on only when tub is full. Again my manual says nothing on this!!
Sep 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have a whirlpool dryer, i tokk the tub out but i don't know how to put the belt back on. its a metal peice with a white wheel on it and i can't figue it out
hi,
okay get the belt around the motor shaft and get the spring clip into its position tab into the bottom of the dryer, the belt goes up and over it by pushing either up or down on the metal piece, the metal piece acts as a spring tensioner for the belt, you may have to either bend it up or down to get it positioned correctly..(the last pic)
jm
Jan 06, 2011 | Whirlpool Dryers
Washing machine making loud rattling noises and smells of burning rubber
Your washing machine has a belt on a pulley and that belt is being stretched. That belt is attached to a motor that turns your laundry tub. Your washer if out of balance will shake and rattle and the tub might be locked in place and the motor is forcing the belt to turn but the tub is not turning. If you are not mechanically inclined call a washer service repair man.
Oct 01, 2009 | Admiral Washing Machines
Kenmore Washer hums during spin cycle
Either the bearings are frozen, or motor is weakening and has hard turning belt and tub/agitiator
Sep 15, 2009 | Kenmore 24032\24036 Top Load Washer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
Roper RES7646KQ Electric Dryer Logo
37 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
