Question about KitchenAid KSRK25IL Side by Side Refrigerator
Water filter won't turn stuck - KitchenAid KSRK25IL Side by Side Refrigerator
Water filter is stuck in unlock position and won't come out
more likely it was in twisted condition when it was turned to luck it or unlock it and stayed in twisted position and will not turn. get a hair dryer and blow the hot air around where it lucks. push filter in and turn to unlock it. hot air expand the lucking plastic cover and it allows for easy turns
Oct 24, 2017 | Samsung RS2556 Side by Side Refrigerator
Tip
Removing Whole House Filters
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
http://i.fixya.neth2oservices.jpg
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
on May 30, 2011 | Culligan Under Sink Water Filter
Filter stuck
It could be frozen, allow it to heat up some and try again. If not remove the filter cover and the filter will be easily removed.
Jun 30, 2013 | Electrolux Refrigerators
Whirlpool side by side fridge won't dispense water.
Most likely the problem is related to a defective water control valve on the dispenser side of the valve. If your model is the ED2FHEXN it will use the=> W10408179 Water Inlet Valve
You should always turn the water supply off before removing the filter cartridge just to insure less water clean up should a water valve be stuck open. At this point I still believe that the water control valve is at fault for not allowing water flow to the dispenser. Here is a parts manual=> ED2FHEXN Parts Manual and here is a link to your ED2FHEXN User Manual You may get some water flow spraying should there be a valve stuck open but that is not the cause of you not getting water to the dispenser. Your ice maker is still working right? I will be here should you have questions or comments, Thanks Sea Breeze
Mar 05, 2013 | Whirlpool ED2FHEXN Side by Side...
please try it according to filter catalogue.
Mar 02, 2013 | Maytag Amana / UKF8001AXX Swift Water...
Water dispenser on Kitchenaid side by side fridge running continuously
There is a filter but it sounds like the water valve in the back was stuck in the open position at first and now won't open at all or the micro switch is actuated when you press the water release is bad, but if I were to bet I would go with the water valve being bad, but change the filter anyway, there is no telling how old the one that is in there is.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | Refrigerators
My Indesit WIL163 is stuck washing - won't go on
I suspect that the logic board has developed a fault and probably needs replacing. 'Phone your Indesit Service Centre and get an engineer out. I believe a replacement board costs about £100 fitted, but a 12-month service plan paid monthly may be a bit cheaper, and will cover further breakdowns. Unfortunately, these boards are not the most robust or reliable examples of technology.
Turn off the power to the machine; preferably unplug it.
If you can open the door(?), bale out the drum by hand. I don't think there's a pump/filter access panel on this machine, so it's not easy to get the water out. You could try
disconnecting the discharge hose from the pipework, then lower the open end over a washing-up bowl so that the water drains from the drum by gravity. It depends how close to the floor you can get the open end. When enough water has drained, it should be possible to open the door to remove the laundry. Sorry, this may take a while.
Hope this has helped.
Jan 11, 2018 | Washing Machines
My dishwasher is filled with water and won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Won,t drian the water.
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
KitchenAid KSRK25IL Side by Side Refrigerator Logo
162 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
