Question about Whirlpool GGQ8831L Gas Dryer
Dryer does everything right but heating i might have a problem with the heater if it has one. how can i replace that
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 23, 2010
Model lec8858eq2 no heat checked all replaced bad heating element everything else has continuity. Only thing I'm stumped is continuity reads 9 on fuse connected right by heating element help!!!!! W
Check your power source. The controls use 120V, but the heater uses 240V. Also, check for loose connections on power source.
(Make sure power is disconnected when checking continuity.)
Feb 19, 2017 | Dryers
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
Apparently the heat element has gone bad. Everything works, but no heat. It is only about 13 months old, could the heat element have burned out already and if so can a average repairman replace the part....
if you dryer is gas check out this gas no heat tip....
check out this electric no heat tip...
heatman101
Jan 22, 2011 | Samsung DV218AEW Electric Dryer
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Need instructions on replacing heating element in whirlpool gold dryer model GEQ9800LW
For the model number you have listed, you can replace the heating element by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside the dryer even when it is shut off.
2. Remove the lower toe panel under the dryer door. The panel comes off by inserting a putty knife along the top seam of the panel about 2 inches in from each side. There is a retaining clip on each side that you must depress in order for the panel to pop open. Open the panel and remove.
3. Open the dryer door and remove the lint filter. NOTE: You cannot remove the blower fan duct assembly with the lint screen in place (next step).
4. Locate the screws that hold the blower fan duct assembly in place and remove. Remove the ground wire and auto dry sensor wire as well (if attached to the duct assembly).
5. With the blower fan duct assembly removed, the heating element should be easily accessible on the right hand side.
6. Locate the Hi-Limit Thermostat and Thermal Cut-Out (TCO) located on the left-hand side of the heater box (these are the two small components on the outside of the heater box with wires attached to them on the left hand side. Disconnect the wires. NOTE: Make sure you label where they go.
7. The entire heater box with all components attached will come out by removing a single screw on the front bracket. Remove the screw and the entire heater box will pull free of the exhaust duct in the rear.
8. With the heater box removed, the heating element will pull out from the front by removing the mounting screws along the side of the heater box.
You can view and exploded view diagram of what I am describing by going to pcappliancerepair.com. The heating components are listed under Section 3.
The list of components are as follows:
Heating Element - Item 14
Blower Fan Duct Assembly - Item 45
Heater Box - Item 46
Thermal Cut-Out - Item 47
Hi-Limit Thermostat - Item 48
Heater Box Bracket - Item 50
If you have questions, please let me know.
NOTE: If you are experiencing problems with the dryer not producing heat, it may not be the heating. If you've confirmed the heating element to be faulty, great. If you haven't, please read through the following:
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
The part numbers you may need are as follows:
Heating Element - 3387747
Thermal Cut-Out/Thermostat Kit - 279769
NOTE: If a replacement power cord is required, you can purchase them at any hardware store.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Nov 22, 2009 | Whirlpool GGQ8831L Gas Dryer
No heat from dryer
remove the back and check the heater box fuse upper left on heater box,and check the heating element bottom part of heater box,the heat box is located to the right of the back of dryer-mike
Apr 29, 2009 | Kenmore 63942 Dryer
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
Duet dryer mod YGEW9200LW1 wont throw heat. It goes through sensing but no heat.
coul be a fuse pn: 279973 or heater pn:3387747
I don't believe that is a heater because its a new machine.
You can get the parts at sears . com and search for parts.
If you open the botton plate of your dryer you gonna see at the right side the heater and screwed into the heater is a thermostat and a fuse.
Before replace the heater , make sure that your vent is cleaning otherwise its gonna blow again
Apr 16, 2008 | Whirlpool GEW9200L Electric Dryer
Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Feb 23, 2008 | Kenmore 63942 Dryer
Whirlpool GGQ8831L Gas Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
