Question about JBL PRX518S Subwoofer Speaker
Hi, I have 2 JBL Subs PRX 518S (and 2 PRX 535). At a gig a few months ago both subs suddenly went "dead" . The powerlight went out, and the did not restart after powering down. The Crown-amps were repaired. One works perfectly now, the other one is repaired 2 times now, but every time I build it in the sub and plug the speaker in the amp goes "dead" again ! Dirk at Werchter Belgium Europe
I had to buy a complete amp and replace the old
Posted on Oct 07, 2010
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
Pull the input plate off of the back, there are usually light bulbs in there that act as fuses
My bass cuts when playing but goes back on after a few seconds.
that because you have a loose ground to your amp or not the right size wire but check your ground on the amp it will overheat and turn off to protect itself .
Apr 13, 2012 | JBL PRX 518S PRX518S Powered Subwoofer PA...
Played at a gig last night when one of my jblprx518 subs cut out also there was a smell as if something had burnt out! Is there a simple quick fix or is it a warranty issue?
Either the speaker or the amp in it or both fried. Check to see IF your warranty will cover the repair.
Make sure that in your venues ALL interconnected equipment is powered from teh same receptacle OR power conditioner module, incling mixers, amps, speakers. Ground bounceof wiring in building power that causes damage most likely will not be covered under warranty.
Jul 31, 2011 | JBL PRX 518S PRX518S Powered Subwoofer PA...
I have two 12" Alpine Type-R subs running on a
9check connections inside sub enclosure(assuming they are in one)mine loosen up after running them hard for months on end.they act the same way yours are.
Jan 24, 2018 | Alpine Type-R SWR-1222D Car Subwoofer
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
JBL PRX518S Subwoofer Speaker Logo
642 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
